lanch control on s3 8l
Cargo Oct 21, 2013
  1. Cargo
    Cargo Member
    32
    Has any one had launch control on there s3 8l if so
    Is it safe.
    Im getting my s3 remaped at end of month and the guy
    Doing it says he can put launch control and flat shift on it for
    Extra £50 is it worth it and is it possible to do it
    Im new to the site and would like to say hi to all
  2. Andrew@A.L.D
    3,879
    617
    There is a few people on here that's had it mapped into the ecu me included
    yes it's safe if used in moderation, can be a bit antisocial and not recommended using it on the public road
    it can do damage to exhausts and clutch are the main things to go
  3. Cargo
    Cargo Member
    32
    Thanks for the reply much appreciated
    Mite go for it for track days would the standard clutch b alright after a few launches
    Or would it b shot after 1
  4. <tuffty/>
    21,874
    4,201
    Launch control and NLS can and will break things so use with caution...
  5. <tuffty/>
    21,874
    4,201
    Std clutch won't last 5 mins for launch and NLS mate... not trying to sound negative as I have this myself but launching a quattro S3 is very hard on everything...
    CMcKenzie likes this.
  6. Andrew@A.L.D
    3,879
    617
    I twisted a few of my driveshafts doing hard launches but i do have over 500bhp
    TBH i don't know how long your clutch will last, is it new? what power are your running etc etc
  7. jojo
    28,998
    3,651
    Launch control on an S3, isn't that what Haldex is for?
    TwinCamMan and vivalacoulter like this.
  8. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    i ****ed my turbo using launch and NLS, expensive way to show off imho
  9. CMcKenzie
    CMcKenzie It's supposed to do that..
    318
    127
    43
    Is it wrong that that video gets me slightly aroused.. :lmfao:
    AVLO likes this.
  10. Cargo
    Cargo Member
    32
    Not sure on power its got ko4hybrid turbo relentless v3 manifold and down pipe milteck decat and backbox
    Badger5 tip cda air filter 4bar fpr forge fmic and recirclulater valve and blue haldex
  11. Cargo
    Cargo Member
    32
    Just had new clutch fitted as well
  12. <tuffty/>
    21,874
    4,201
    Rods?
  13. Cargo
    Cargo Member
    32
    Agu bottom end amk head
  14. Andrew@A.L.D
    3,879
    617
    Yes that engine will have rods :banghead:
  15. IrishDave
    IrishDave Active Member
    682
    45
    Good luck.........
  16. Gops
    3,198
    666
    I've been thinking about this recently.. Lately, when my ESP kicks in, my car burbles like an rs3 on launch.. But as soon as it gets traction it just launches off without lag.. So it must be some boost building esp? Can this not be used for LC?
  17. badger5
    9,599
    2,060
    LOL
    well there will be some fragile pieces of metal attaching crank to piston in there... probably for a short while anyhows :p
    limbo118118 and phil miller like this.
  18. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,496
    212
    To the O.P
    they were asking if you had uprated rods, as with your list of mods you are running in the 290bhp + bracket or 290+ torques bracket and that is what we call " rod bending territory" ........... Very expensive damage to the engine if they go.
    Sean
  19. Cargo
    Cargo Member
    32
    [vvQUOTE=s33nyboy12;1994858]To the O.P
    Sean[/QUOTE]
  20. badger5
    9,599
    2,060
    you gotta luv the "specialist advise" received
    this is what you also need to account for:
  21. Cargo
    Cargo Member
    32
    Not to bad if it goes got a spare s3 am braking in garage
    Alot of work doing it but atleast i got spares lol
  22. AVLO
    AVLO Active Member
    295
    52
    When people say launch control then is this as in a anti-lag system or is it just in the same was as holding throttle at 4500rpm??
  23. <tuffty/>
    21,874
    4,201
    Boost build launch is the official name for it really... uses an 'anti-lag' type approach to build boost at a defined rpm... the code holds the rpm at the mapped set point (4.5k on mine for example), the boost builds from the 'anti-lag' like stuff, drop the clutch and off you go...
    AVLO likes this.
  24. AVLO
    AVLO Active Member
    295
    52
    ^^^^^ sounds like fun with moderation ;-)
  25. <tuffty/>
    21,874
    4,201
    Sounds a bit pants in this but you get the idea....
  26. Cargo
    Cargo Member
    32
    Sounds sweet and looks quick what bhp is that running
  27. <tuffty/>
    21,874
    4,201
    at the time of the video, 400hp... currently nothing as the engine is on a stand and the new turbo in a box :)
    AVLO likes this.
  28. Scullies
    Scullies Well-Known Member
    1,543
    658
    So do you literally just drop the clutch and it goes or do you need to ride it a bit.
    Do you know roughly how much HP the engine is making at launch?
    I like this but I'm scared
  29. Andrew@A.L.D
    3,879
    617
    No riding
    Clutch down, acceloratoer to the floor, revving to 4500 and holding, clutch out and hold on
    Have a look at your dyno graph to see how much power your making at 4500
    AVLO likes this.
  30. Scullies
    1,543
    658
    HO LEE CHIT, now Im even more scared for my gearbox and drive shaft
    AVLO likes this.
  31. Andrew@A.L.D
    3,879
    617
  32. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Make some solid shafts?
  33. Andrew@A.L.D
    3,879
    617
    It's a weight thing the but that will be the next thing with me as I'm upping the power
