lamnda problem , and low air flow
nick-barnes07 Jul 22, 2007
  1. nick-barnes07
    nick-barnes07 Member
    554
    plugged vag com into my s3 today , and it came up with air/oxygen sensor intermittent , i take it that is a dodgy lamnda , and my air flow was 188g/s in 3rd gear , the car has a mrc map and a 3" downpipe , de cat , miltek cat back , and loads of other bits , it is also boosting at 15psi , instead of 20 , and the vacuum is down to 10 , instead of 30 , do you reckon this could be down to the lamnda sensor , as the maf is less than a month old , i bought a brand new one from gsf the whole unit ,
  2. shineydave
    shineydave Member
    920
    G/S through the MAF sounds about right, you could try unplugging it and see what happens but i think your Lambda diagnosis sounds right
  3. nick-barnes07
    554
    what do you mean , that i dont need a new lamnda , it was getting 227 g/s air flow the other week , its got a map on it
  4. shineydave
    shineydave Member
    920
    i thought a mapped car did about 190g/s
  5. stevegti6
    stevegti6 New Member
    10
    it might be a lamba fault try another one but it seems down for your model it should pull more than that being a k04
  6. nick-barnes07
    554
    my old lcr pulled around 220 g/s with a custom code map , i think 190 is a bit low for a k04 with a map on , i may be wrong ,
