LaminX - order from US?
Agent_Trig Jul 13, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    Anyone ordered this from the US before?
    Audi A3 (2006, 2007, 2008) Headlight Covers
    I know you can buy it over here, but from the US it is pre cut to size and comes with all the tools you need.
    Will I get stung at customs?
  2. Rhyso
    Rhyso Well-Known Member
    1,525
    318
    Nope; just received mine last week :) Paid £38 in total for headlight and fog covers delivered. Took about 10 days from order to landing on my doorstep
    Here's a pic of the stuff fitted
  3. Agent_Trig
    Agent_Trig Member
    552
    How easy was it to fit? I'm having the same colour combo as yours too... sorry about that :)
    Did you have to remove the fogs to fit the film and if so, does this require a bumper removal?
  4. Rhyso
    1,525
    318
    Very simple to fit; make sure your headlights are UBER clean, switch on your headlights to warm up the lens, then using the bottle they send you mist the headlights with clean water and then apply the headlights and use a squeegee to push all the bubbles out
    Fogs are the same and no need to remove the bumper; just pull off the plastic surround and then undo the 3 screws holding the fogs in if you want to remove them completely
  5. Agent_Trig
    Agent_Trig Member
    552
    Nice one - I'll get this done asap :)
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    Starting next year for the MOT tints on lights will fail if they reduce the light output "significantly". The Laminx could well be ok but its just something to be aware off.
  7. Agent_Trig
    Agent_Trig Member
    552
    I'll only be going for the 6% tints like above so should be fine.
  8. wez3570
    wez3570 Member
    704
    20
    I read its best to buy a cheap bottle of water for the little atomiser. The chlorine in tapwater can have a detrimental effect over time.
    Tapatalk for iOS
  9. Rhyso
    1,525
    318
    Hopefully a combination of uprated bulbs and the lightest tint available I'll be ok; cheers for the heads up though :)
  10. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,323
    188
    Will they stand Xenon heat :)?
