Lambo vs Toyota!
Caesium Jan 2, 2008
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
  2. RGBArgee
    RGBArgee Guest
  3. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    845
    Never seen the interior of an LP640 before, personally I think it looks far too Audi'ish for a Lambo, thought it was a TT until they showed the engine!!! As for the race, of course a 1200hp Supra is going to win, it'll blow up afterwards but it'll win!!!
  4. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    its a lambo look at the mirrors! cant believe how quick that supra is!
  5. jojo
    28,907
    3,563
    That's the type of performance you are after right Ed? :icon_thumright:
  6. Caesium
    4,879
    Unlikely to blow up, the JZA-80 engine in the Supra is one of the strongest bottom ends of any engine ever. It will take up to 650 horsepower with no modifications at all, thats double the standard power. No other engine I have ever heard of will do that.
  7. simch
    simch Active Member
    2,028
    Er loads of 18T 150hp running over 300 on Big Turbos! !
    But those supra motors are animals!!
  8. Caesium
    4,879
    you can get 300bhp out of a 1.8 without ANY bottom end mods at all?
  9. emzino
    emzino Active Member
    1,231
    What do you mean when you say, "bottom end mods"
  10. Caesium
    4,879
    Anything altered to the engine below the cylinder head, any oil pump upgrades or oil coolers, bearing changes or uprated con rods or crank etc.
    The video from the supra is on that page now also.
  11. jojo
    28,907
    3,563
    No the standard internals of a 1.8T can take around 325BHP and the same amount in torque, but you will need to uprate the conrods, valves and possibly pistons to go over 325bhp safely.
  12. Caesium
    4,879
    isn't the 1.8 already at 230 by the manufacturer in the S3?
    if so 320 isn't double the output.
    The standard Jap spec supra is 280bhp, so by rights if we're going on the lowest output for that engine, you can more than double its output on a standard bottom end.
    Nothing against the Audi engine, but the Toyota engine is in a different class, anyone that has worked on one will say the same (anyone with a modicum of intelligence anyway)
  13. simch
    simch Active Member
    2,028
    I refer you to the earlier comment!! !
    Litterally LOADS of AGU, 150hp golfs running well over 300hp, with totally stock engines, just a ruddy big turbo bolted on.
    No rods, no head off, no pistons, just the stock AGU running IHI or GTrS.
    Stock motor from VW 150hp, I know of one running over 360hp with aquamist and 148k miles on it, converted at 79k miles 4.5 years ago!!!
  14. 2low4u
    2low4u Active Member
    199
    42
    I know of 2 VR6 turbo's running 400 bhp+ on standard internals, both with over 100k on the clock and still going strong - standard power is circa 190bhp.
  15. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    Hasn't anyone realised the guy is HUGE!!! a slight weight issue with the weight on the lambo (me thnks) :beerchug:
  16. HTC
    HTC Active Member
    3,428
    9
    I want to see more of that Supra.
  17. danotto
    danotto VAG HUNTER
    1,090
    how gutted would you be knowing that you have spent almost 150k and you get ripped by a 6k toyota from 1995.
    mind you i know which one id rather own....lambo
  18. HTC
    HTC Active Member
    3,428
    9
    I think the big guy owns both cars.
  19. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    It's amazing what a little NOS will do hey
  20. Von Maximo
    Von Maximo The Damned
    344
    In my opinion anyone can make a car go fast in a straight line, but making a car that handles more power than what it's chassis, brakes, clutch etc was originally designed to do and it's a totally different kettle of fish.
    Each car has been designed to handle the power and tolerances that it's engine produces. Alter it to such an extent as the supra in this clip and your asking a bit too much. I'm sure if they had a race around a track it would be a different story. . . . . I know which one would not only win, but would also mechanically last longer!
