Lambda Wiring Diagram ?
A3 T Jan 12, 2014
  1. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    Does anyone have a wiring diagram on the lambda sensors ?
    I want to check all the wiring and need to know if the wires that go to the sensors go straight to the ecu or if they go to the fuse box first.
  2. Broken Byzan
    13,237
    466
    all bar one goes to the ecu, that one goes to fuse box + 12 ve
  3. A3 T
    1,077
    15
    Thanks for that ;)
    Is it the pre or post cat one that goes to the fuse box ?
  4. Lewis583
    956
    91
    They both utilise the same feed. F43 10AMP. Also using this feed is MAF/EVAP valve/SAI solenoid/SAI relay.
  5. A3 T
    1,077
    15
    So are you saying that they both go to a 12 amp fuse in the drivers side fuse box before going to the ecu?
    Also if their on the same feed as the MAF, could a dodgy MAF bring up the error code I'm getting tin this thread:
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/202985-b1-s2.html
