LAMBDA SENSOR
crackers187 Sep 8, 2009
  1. crackers187
    crackers187 New Member
    9
    hi..i bought a remapped s3 a few months back & recently the lambda sensor needed replacing..since then i feel as though its lost a bit power in the first few gears
    i just wanted to know whether replacing the lambda sensor could have any effect on the remapping of the car
    any positive respoonsies would be appreciated
    cheers
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    How do you know the lambda needs repalcing? Have you tried to scan for any fault codes?
  3. hooley
    hooley Member
    199
    Was the Lambda replaced or still needing to be replaced?
    It will alter feuling as it measures the combustion gasses and alters the feuling map to suit.
    I recently replaced mine and the torque now kicks in nicely from 2.4k whereas before with the knackered lambda it was 2.9k and running quite a bit lean.
    I left mine too long and think i've burnt a valve. Bummer.
    J
  4. barters3
    barters3 Member
    438
    i have had a lambada fault come up on vagcom, the car seems to run fine, is it still advisable to replace it?
  5. crackers187
    9
    i took it to an local audi specialist becuase the engine managemnt light came on..and after a diagnostic check it came up with a fault with the lambda sensor and the reading 'low performance'
    i got a changed a few days later..& since then there doesnt seem to be as much power on take off as before
    if i take it to a garage that specialises in remapping..would they be able to check the bhp of the car..?
  6. hooley
    hooley Member
    199
    You can calculate power from the torque measured through a VAG-COM
    feul map is thought to be a basic map. As my car was chipped the basic ceiling map made the car run lean and hence burnt a small hole in a valve. If the car is standard you should be fine but lacking in performance and economy.
    Jas
  7. hooley
    hooley Member
    199
    bloody iPhones.
    Should read "feuling map". Apologies
    J.
