lambda sensor question
s3gazz Jan 12, 2011
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    hi i have a amk 225 s3 and need the lambda sensor for my down pipe is it the same as the one near cat or not and how many wires does it have tar
  2. Speedy Steve
    Speedy Steve Active Member
    1,258
    They are different to each other if i remember right the top one has 5 wires and the bottom 4 but it could be the other way round been a while since i did mine
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Deffo different.
    Had a quick look on euro car parts, but they don't stock a wideband pre cat sensor sadly.
  4. s3gazz
    1,383
    105
    iv been quoted 60 from gfs for down pipe one that seems ok to me other one i payed 40
    would it be that thats coursing bad fuel consumption loss of power and **** drive
    or is it the egt sensor tar lads doin head it now maf sensor fault as well god nose witch one it could be argggggggg
  5. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    Both egt and lambda contribute to bad fueling and loss of power
  6. <tuffty/>
    21,695
    4,123
  7. s3gazz
    1,383
    105
  8. <tuffty/>
    21,695
    4,123
    do me a favour and rescan your car for faults and post them up... lets start from there...
  9. s3gazz
    1,383
    105
    thanks tuffty ill post the onto her mate wont be long great help i o u lol
  10. s3gazz
    1,383
    105
    here we go mate
    01314 engine control module
    17833 evap purge valve (n80)
    16955 brake switch f
    16486 mass air flow sensor (g70)
    17523 oxygen lambda sensor heating b1 s1
    17861 exhaust gas temp sensor 1 (g235)
    17525 oxygen lambda sensor heating b1 s2
    some of the other faults have gone since i had my cat took off today so thats abit better
    cheers tuffty
  11. <tuffty/>
    21,695
    4,123
    Having a quick look at some of those codes seem to come up as 'short to ground' as a common description...
    Judging from your ECU 01314 error I am of a mind that the cause of a lot of these errors are due to the ECU picking up another problem
    01314 - Ross-Tech Wiki
    Also digging around I found this..
    VWVortex.com - got 8 codes 17880 17833 17525 17843 etc
    Has some similar codes to yours... all the posts seem to suggest fuel pump relay for some reason... thats a start point at least...
    Google is your actual friend btw ;P
  12. s3gazz
    1,383
    105
    cheers mate great help where is the control module and how will i find fault i best off going to see a car electriction who nose what hes doing
    where is the o2 sensor mate i dont now non of these lol and how much are fuel pumps looks like ill buy one and fit it see what happens canot be that dear
    would u say im still needing lambda sensor or egt sensor and maf or fit fuel pump and go from there this helped alot mate tar
  13. <tuffty/>
    21,695
    4,123
    I think at this point my friend its worth taking it to a specialist...
    O2 sensors are lambdas... fuel pump relay should be under the dash drivers side IIRC but no idea what one...
    I would personally get the car checked over by a qualified auto electrician as all the faults you have appear to be the result of a larger problem... I suspect if the initial problem is fixed then most of the other faults should clear...
  14. s3gazz
    1,383
    105
    thanks mate ill do that then and leave all those things for now ill change fuel pump see what crack is tar again tuffty
  15. <tuffty/>
    21,695
    4,123
    Fuel pump? fuel pump relay you mean....
  16. s3gazz
    1,383
    105
    soz mate ye i was messing around under there fitting a brake switch last week could i ov nocked something tuffty
