Lambda sensor intermittent fault code
1animal1 Nov 21, 2010
  1. 1animal1
    9,978
    as above chaps, keeps throwing the engine management light on (happened twice now in two weeks)...will this affect the MOT due next month? also i'm guessing its more than likely a straight replace item once some poor sod has got it out...it says in the fault log, pre CAT if that helps?
    Also any other issues i'm likely to suffer?
    VCDS-Lite Version: Release 1.0
    Sunday, 21 November 2010, 18:47:24:0
    Control Module Part Number: 8N0 906 018 BH
    Component and/or Version: 1.8L R4/5VT 0001
    Software Coding: 10710
    Work Shop Code: WSC 14132
    Additional Info: WAUZZZ8L121014466 AUZ7Z0A2015117
    2 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
    P1116 - 35-10 - - - Intermittent
    17511 - Shareware Version. To Decode all DTCs
    P1103 - 35-10 - Please Register/Activate - Intermittent
    chars :)
  2. Prawn
    11,536
    3,480
    wierd man. This on the A3 or S3?
    I know if the sensor heating fails it'll effect it. Perhaps worth checking the wiring connection, and if it's OK, look at a new sensor perhaps.
  3. 1animal1
    9,978
    mechanic i know says its fine for emissions if its just the heater which this seems to be...... interesting conflict here mate.
    It's going into Audi tomorrow for the roof to be done and i've cleared the fault, hopefully it will surface again and i can blame them :) (they have to drive it all the way across the city to the bodyshop ;) )
  4. finesse
    finesse Active Member
    2,805
    B1 S1 is the pre cat sensor
    I got my lambda replacement from ECP
  5. finesse
    2,805
  6. 1animal1
    9,978
    cheers John.....its on the underside of the mani on ours though isnt it.....think ill chuck it to my trusty neighbour as he'll have a ramp and hot spanners in necessary.
    looks so much easier on the 1.6 engine :)
    i gather this wont harm the car?
  7. finesse
    2,805
    errrmmm I was "told" that it can affect the catalyst
    I don't know how,
    anyway it will affect your fuelling for sure
  8. 1animal1
    9,978
    yeah it will be the same as if the SAI was taken off the early models, think it burns excess fuel to stop it hitting the CAT and destroying it from cold (as they CAT isnt at its operating temp)
  9. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I changed mine about 2 years ago...Was a pain until i borrowed the correct spanner
  10. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Yeah, it is a bit of a bitch to get to, but do-able. Access is much easier with the rear charge pipe support removed. Changed mine twice now... lol.
    I always use my trusty adjustable.
  11. S3 Paul
    2,825
    107
    Ive changed mine twice too, Turns out i forgot to clear the code... sensor was fine.
    silly mistake
  12. 1animal1
    9,978
    cheers chaps....Paul what did you do with the spare sensor :)
  13. S3 Paul
    2,825
    107
    Put it in the box marked "spares" lol
  14. finesse
    2,805
    thought its just me not throwing parts away.........
  15. S3 Paul
    2,825
    107
    If only i did throw stuff away. would have an empty flat/shed and unit.
  16. 1animal1
    9,978
    you taking offers for any of that trash :)
