Lambda for S3 part number
Welly Dec 7, 2009
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Anyone know the VAG part number for this part?
    I want to phone around tomorrow to see if I can get a genuine one cheaper than the £300,000 that the stealers want.
  2. <tuffty/>
    21,353
    3,921
    Look to be about £50 ish from GSF
  3. Welly
    10,696
    129
    Are they Genuine/As good as genuine ones? Also, do you have a link handy?
    Ta :)
  4. S3KO4
    S3KO4 Member
    850
    You can also try eurocarparts
  5. Welly
    10,696
    129
    Well, they're nice and cheap.... Not! I couldn't find one on GSF Tuffty, EuroCarParts have them, but again, on the steep side...
    Are they all as good as each other or what? I wouldn't of thought a pattern parts would be as good as a Bosch one...
  6. Fuzzy felt
    Fuzzy felt Member
    101
    Just out of interest, how much are the stealers quoting you for one ? i had a new one put in my car the other day, and it hasn't fixed it !
  7. Welly
    10,696
    129
    About 95 quid but I'm gonna try and beat them down!! Its defo a Lambda failure - Malfunction In Circuit = FUBAR
  8. Fuzzy felt
    Fuzzy felt Member
    101
    yeah, that's what i paid, i'll be interested to see how you get on, mine keeps bringing the warning light back on after it was changed.
  9. Welly
    10,696
    129
    No warning lights for me, just a big fat error in VAG COM :(
  10. Stan1.8T
    Stan1.8T New Member
    22
    Yeah,
    I'm also probably going to need to buy a new sensor, so Im also on the look out as to where to get one.
    I got an engine managment light yesterday and did a scan and got 2 codes:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
    P1116 - 35-00 - -
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
    P1103 - 35-00 - -
    Sorry to hijack the thread a little, but if anyone can point as to how to locate this sensor on the car, that would be very helpful!
    Also are these sensors reasonably straight forward to replace?
    Thanks!
  11. Welly
    10,696
    129
    No worries. B1 S1 is the one directly on the downpipe, you can see it if you look down the back of the engine.
  12. <tuffty/>
    21,353
    3,921
    Your nearest GSF branches are : Cheltenham
    Unit 36, Lansdown Ind. Est
    Gloucester Road
    Cheltenham
    01242 225620
    Give them a call mate, parts they sell are made by the same people that VAG get them from only they are half the price because they don't have the 4 rings...
    It'll be a Bosch part I would imagine. On their site, you have to search for the A3 as they don't list S3 on the site... give them your reg number or VIN number and they will get a price for you.
  13. <tuffty/>
    21,353
    3,921
  14. Stan1.8T
    Stan1.8T New Member
    22
    Cheers, will have a look tomorrow and see if I can spot it.
    Been looking for replacements and found 2..
    On GSF they are £84.53 inc vat and post. I found them searching for "lambda" through A3 option.
    On Eurocarparts I found the Bosch one, which is much cheaper at £55. Link here
    Not sure which to go for :S The Bosch one should be fine shouldn't it?
    Again, cheers for the help!
  15. Welly
    10,696
    129
  16. Welly
    10,696
    129
    Normally reasonably easy, but often need a lot of WD40 to soak through, they can be TIGHT!
  17. Welly
    10,696
    129
    Well, I've ended up getting an NGK one from GMF in Gloucester (My mate works there... *trade*). £83 all done, although not trade it was about the same price as the stealers to be fair...
  18. Welly
    10,696
    129
    It'll be fine assuming you have an AGU engine?
  19. hharry100
    hharry100 Member
    49
    had mine replaced as it had the same fault codes with a bosh unit from euro car parts but still showing same fault code coming up?????????????????????
  20. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    NGK are pretty dam good mate i sell them & no problems with them :)
    As for you O.E part number sorry its late.
    06A 906 262 R
    06A 906 262 AJ
    Im guessing you brought a NGK stock code number - 0388 ? 4 wire fitted after the cat ?
  21. hharry100
    hharry100 Member
    49
    does anyone know if the Genuine Audi Lambda sensor is Bosch or NGk, I have the Bosch one from Euro car parts but this is still bringing up erroe codes:
    P1116 - 35-00 - -
    P1103 - 35-00 - -
    I have now returned the first one i bought as i thought it was faulty but im still getting the same error codes with the replacement.
  22. Welly
    10,696
    129
    OEM item is Bosch.
  23. Dazboss
    366
    :iagree:Yep
  24. finesse
    finesse Active Member
    2,805
    Where is Lambda B1 S2 located please?
  25. hharry100
    hharry100 Member
    49
    This would be the sensor after the cat under the car
  26. 1animal1
    9,978
    Welly....these parts wouldnt go if you drove sensibly :p
  27. Welly
    10,696
    129
    If I wanted to drive sensibly I would of bought a 1.6..... lol. :thumbsup:
  28. hharry100
    hharry100 Member
    49
    Just wanted to update you guys, just had my car fail its mot on emmisions CO level was meant to be bellow 0.300 mine was ten ttime over at around 3.250,
    decided to spend the day to get to the bottom of this problem so started by disconecting MAF which made no difference, took out spark plugs to check which were dirty but still in working order. so i decided to disconect and reconnect lambda sensor which still gave me the errors i was having earlier, So i disconnected the battery and left it for 10 minutes and then reconnected it, when i started it it seemed to start better and i took it for a raz and it deffinatley felt like it was running better also no fault codes reappeared.
    Just visited the mot centre for a re-test and Wooohooo it passed so seem like all is good with the S3 once again :)
  29. hharry100
    hharry100 Member
    49
  30. finesse
    2,805
    Welly, how is your NGK lambda so far? I am thinking of getting a Bosch version from ECP but I do not know if it will require extra work, such as cutting wires to fit...
  31. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,577
    1,492
    EuroCarPArts supply a proper Bosch lambda sensor, which has a rather long wire with the correct plug for the A/S3, but it means that you can fit it before or after the CAT. Linky
    It's a bit more expensive than what I paid for it last year though @ £70
    I saw load of them on ebay, but what sold me on this is that it's Bosch and I didn't have to mess about with the wiring.
  32. Ruin20
    Ruin20 New Member
    23
    I got a Bosch one recently from ECP for my AMK, it cost just over £77 and it plugged straight in part number was 710442665 I believe, that was a post cat sensor though
  33. finesse
    2,805
    thanks leskin and ruin20; fitting one tomorrow
