Lack of Boost
mdre83 May 24, 2013
  1. mdre83
    mdre83 Member
    634
    Peeps,
    Slight problem, been having DPF "issues". Because I'm only doing short journeys through the week I was having to take it for a blast to clear the DPF every week.
    About 3 weeks ago I added DPF cleaner to the fuel tank. Light hasn't re-appeared since however, I now seem to be lacking boost in the low ranges. DPF light still not on dash and turbo is kicking in but much later than what it used too.
    You can feel it want to pull but there's nothing there until higher revs.
    Surely if it was the DPF causing this the dash light would appear and or the car would go into limp mode.
    Anyone any ideas what this could be?
    Cheers,
    Martin
  2. NHN
    29,576
    1,779
    I would force regen a few times with vcds & then see how it goes.
  3. mdre83
    mdre83 Member
    634
    Cheers Nigel, where in the country are you again mate?
    I guess my local garage could do this too?
  4. NHN
    29,576
    1,779
    South East, atm.
  5. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Maybe someone local with VCDS could help you out with the force regen?
  6. mdre83
    mdre83 Member
    634
    ok I'm not convinced the DPF is the issue. I've been on some long journeys lately so I guess all the **** should be burnt off.
    I can feel the power waiting to kick in, but nothing. Any ideas what else it could be?
    An engine clean up in needed due to the dip stick not being replaced correctly after a previous service. Maybe something is clogged, a valve not opening/closing correctly somewhere?
  7. mdre83
    mdre83 Member
    634
    DPF and EGR valve cleaner ran through but still, the lack of boost is still there... anyone got any ideas?
