lack of boost/ inconsistent boost
brent 3045 Sep 6, 2012
  1. brent 3045
    brent 3045 Member
    98
    driving home from work today when car just seemed to be running misfiry, checked vagcom when i got home and this code is on
    p1456 - 17864 - exhaust gas temp control bank 1 limit attained - intermittent
    any ideas?
  2. Paradox1
    Paradox1 Active Member
    1,833
    88
    I'm on my phone at the mo but put the code in google and see what it says
  3. brent 3045
    brent 3045 Member
    98
    i have already but there nothing on ross tech, not much info on it at all on google neither, was hoping you guys could tell me where to start
  4. badger5
    9,400
    1,944
    log block 112... if its 1100'c its goosed egt sensor.. and it will fuel dump
  5. brent 3045
    brent 3045 Member
    98
    i removed my egt sensor today after finding where it was located and it looked kinda corroded, so i wire brushed it. put it back in and took it for spin. car felt better, no code but while i was logging, temps got upto 950c. is that a problem? didnt really push it to the limit tho
  6. <tuffty/>
    20,896
    3,705
    950deg is fairly normal when ragging a K04 turbo'd car but if yours threw that code (I have seen this one myself but for different reasons) I would suspect (as Bill has already said) the EGT sensor is on its way out... intermittent means just that...
  7. brent 3045
    brent 3045 Member
    98
    ok thanks, already got egt sensor off my friend just in case. will try the new one tomor, thanks again
