L.E.D. NUMBER PLATE BULB no errors on My B8
KoFidee Oct 29, 2010
  1. KoFidee
    KoFidee S-LINE
    149
    Fitted these to My 09 B8 no errors worked 1st time look cool
    Item number: 390101769391 (ebay uk)
  2. Necroscope
    Necroscope Member
    254
    Cool, did you go for white or blue?
    Let me know how you get on over the next week or so, and do you have any photos?
  3. KoFidee
    KoFidee S-LINE
    149
    White will upload some pictures
  4. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I got the same ones after my original LED bulbs failed. They are really good and look great
  5. sduk
    sduk Audi Baby!
    149
    19
    hey! these still working ok? i am considering getting some,
    are they easy to fit?
  6. redspudder
    redspudder Sparky
    371
    I have just bought the LED's but i am struggling with fitting as per my thread any help appreciated
  7. KoFidee
    KoFidee S-LINE
    149
    easy to fit on B8 just pop out number plate lamp holder (no screws)
    then insert new led bulb bit tight fit but will go,
    maybe best to open up the gap between + &- on lampholder ter.minals 1st to accommodate new led lamp
  8. KoFidee
    KoFidee S-LINE
    149
  9. sduk
    sduk Audi Baby!
    149
    19
    they look great! defo gonna buy these on pay day!
  10. redspudder
    redspudder Sparky
    371
    Had a look today and i cannot get the holders just to pop out i put a little force on the holder and it didnt want to budge
  11. KoFidee
    KoFidee S-LINE
    149
    you need to pop them from side with the reccess as one side is plastic clip other side is a metal flat piece spring like effect
  12. redspudder
    redspudder Sparky
    371
    I finally managed to get them out,after reading a post on another forum i tried using a scredriver in the recess and chewed the hell out of the holder,i did not even need to use a srewdriver i just simply pushed and pulled down at the same time with a bit of force with my fingers from the same side as the recess and the holder popped out.Lamps fitted looking good except the holders are now chewed to bits ordered x2 new ones from local dealer at £8 each.
    With regard to the error on the DIS does thid actually work on the number plate lights?I had LED in 1 holder and normal lamp in other switched lights on to see the difference in light and no error code on display, i then removed the 2nd lamp and switched lights on so i only had one LED working and nothing in 2nd holder and i got no lamp out warning on the dash is this correct?if i had lamp out failure on dash i would expect it to b lit if a lmap was removed as there was no circuit made maybe it doesnt work on number plate lights only on the main cluster
