KW V1, front coilovers, only rear springs...?
J Eyo Apr 13, 2014
  1. J Eyo
    J Eyo Polo GTI (6) R
    220
    Hi guys,
    can get a set of kw v1 for $250, the front assemblies are complete, however, no rear shocks, just the adjustable springs, can i run these? They're second hand and from a mk4 gti, can i get koni yellow or bilstein b8's to replace the missing rear shocks?
  2. JimS3
    JimS3 Active Member
    736
    72
    Are they from a 4wd (4motion or r32 golf)?
    2wd setup will not fit your S3, both front and rear are different.
  3. Prawn
    11,605
    3,581
    Fronts will fit. rears won't
  4. JimS3
    JimS3 Active Member
    736
    72
    How would you mount the top of the front drop link into a 2wd shock that doesn't have the bracket for it?
    could fabricate and weld one on, PITA though.
  5. snowy
    snowy Active Member
    438
    107
    43
    Think the simple answer is no
    They would be the wrong ratings even if you could get them on
    As for mixing mixing KW shocks with some other manufacturer sounds like a trip into ditch to me
  6. vroomtshh
    vroomtshh Active Member
    362
    49
    KW fronts all have the bracket
    Prawn likes this.
  7. Prawn
    11,605
    3,581
    As above, all KW struts have the tab for 2wd or 4wd models :)
    Spring rates are also the same at the front I believe. Same engine and main running gear up front....
