  1. gixxer600k4
    gixxer600k4 Member
    692
    have now started looking at the H&R 35mm springs, but I'm think bout going lower, what do u think bout the kw springs 40mm?
    What will the ride be like?
    Cheers guys.
  2. gixxer600k4
    gixxer600k4 Member
    692
    im on the verge of getting some H&R's but im not sure if i want anything lower like the KW 40mm spring, do people think i should go for the better made slightly higher H&R or give the KW's a go?
    cheers for all ur help on this matter
  3. Don76
    Don76 Well-Known Member
    598
    322
    Why not just go for the H&R -50mm springs?
    The picture of Dsaints car running these looks spot on.
    H&R are one of the best mfg's of springs out there....
  4. gixxer600k4
    gixxer600k4 Member
    692
    habe any guys here had issues with tires rubbing when on H&R 50mm
  5. gixxer600k4
    gixxer600k4 Member
    692
    just about to buy the H&R 35mm finally made my mind up, would have gone lower but i need a bit of height left, am on dpm and just wondering what it means about the front axle weight, there is a choice between 'from 1021kg' or 'upto 1020kg' what one do i choose?!
  6. gixxer600k4
    gixxer600k4 Member
    692
    can anyone help me with this as im about to buy!!!!!
  7. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    its only one kg lol diesels are slightly heavyer than petrols so maybe the 1kg heavyer cant damien tell you this ?????if your is petrol get the lighter i should imagin the lighter will sit slightly lower
  8. DPM
    DPM Site Sponsor Site Sponsor
    5,056
    219
    Yeah you should of just emailed or PM'd us mate.
    Your vehicles front axle weight can be found on a white sticker usually under the carpet in the boot, if it's lower then 1020kg you need the 'up to 1020kg' option or if it's 1021kg or over you need the 'from 1021kg' option.
    Damian @ DPM
  9. gixxer600k4
    gixxer600k4 Member
    692
    Lovely cheers mate, yea was going to but I don't want to keep going on bout me lowering my car. LOL cheers again everyone.
  10. gixxer600k4
    gixxer600k4 Member
    692
    Just had a quick look, there are two stickers, both with loads of random numbers and letters. Only number I can find which has any coralation to the question is 1015. So you think this is it. What is the difference between the two?
  11. 10blazin
    3,301
    got to be mate its the lighter ones then.... ive just got mine waiting at dpm but wasnt asked my weight hope mine are right lol...........
  12. gixxer600k4
    gixxer600k4 Member
    692
    what ones did u go for?!
  13. 10blazin
    3,301
    35mm H&rs i have a qauttro and most the springs for some reason are 35 mm not seen any others that go lower but when i saw savs s3 on here i thought yeah looks nice thatle do me............
