Kufatec Sportback rear light adaptor
b19ctr Mar 1, 2011
  1. b19ctr
    b19ctr The King of Cannock
    679
    66
    Anyone fitted the kufatec rear light adaptor to upgrade there Sportback rear lights?
    I've fitted them and there working fine apart form the reverse and fog lights wont come on anyone know what the issue is?
    Chris
  2. hades-
    9,482
    646
    you may have to move a few pins around
  3. *Müllërz
    *Müllërz REVOlutionary
    479
    I had to do some coding on mine
  4. zedzo
    zedzo Member
    149
    whats the point of adapters if u have to move pins about. doubt its that. isnt it to do with vagcom?
  5. hades-
    9,482
    646
    i was going on the last set i fitted
    fog didnt work and i had to move pins
  6. b19ctr
    679
    66
    All sorted now I'll find out what the garage did to get them to work :)
  7. sachen
    sachen Member
    246
    On a side note, the Kufatec website states these lights are not suitable for RHD. Where can i get facelift sportback lights which are suitable?
  8. A4SLineJC
    A4SLineJC Member
    67
  9. A4SLineJC
    A4SLineJC Member
    67
    RHD and LHD only applies to the 3dr model as it relates to which side of the vehicle has the fog light, on the 5dr it doesn't matter as both sides have them in the tailgate lights rather than the outer lights
  10. NHN
    29,601
    1,782
    Thats kufatec for you, but the pins on either side arent identical in location, they would have to be moved to suit according to elsawin.
  11. tcardio
    tcardio Well-Known Member
    1,065
    315
    you need to move pins around and then use vcds for all prefacelifts
    post facelift, no adaptor needed ; only vcds
