Koni FSD Shock Absorbers
spiker Apr 22, 2007
  1. fingermouse
    fingermouse thats me
    4,004
    112
    ok measured to the sil mid way but the stronger part of the body that the sil fastens to and one side is 180 mm the other 190mm
    also measured from the centre of the wheel to the top of the wheel arch and they are from 360mm rear 370mm
  2. spiker
    spiker usually growling at something
    200
    assuming the ride height doesnt change then ?
    are you suggesting the ride height doesnt change without these ?
    i am confused - explain
  3. fingermouse
    4,004
    112
    well mine is std appart from the R32 Arb so if yours is the same height then the rear adjustable bars are not needed ????
    is yours the same height as mine even though is suppose to have lowered springs on it then ???
  4. spiker
    200
    From memory the last time i checked after the mod - the middle of the sill to the ground approx 140mm
    cant find a bleeding tape measure right now as I am away but I will double check
  5. vanilla_ice
    vanilla_ice Active Member
    713
    Spiker,
    Still happy with this setup? Did you / have you got adjustable tie-bars or uprated ARB's?
    ICE
  6. spiker
    200
    havent gotten around to making any other changes but VERY happy with the fsd's - it just makes the ride less harsh and still handles well
  7. jpgibson
    jpgibson New Member
    10
    Ive had H&Rs,KW, now FSD/Eibach
    The H&R's were terrible- knock your fillings out ( bad roads in sydney)
    KW leaked from day one ( not much , but even the replacement ones did)
    Koni- fantastic
