Ko4 tip on A3 help
phil miller Oct 11, 2012
  1. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Hi all today I decided to fit the S3 ko4 tip does anyone have any pics of the layout, like where does the n75 go and when mounting a fmic do the pipes from the n75 and dump valve connect in to the fmic pipe as on the ko3s set up? Also I offered up my air box and its a mile out, how do you get the ko4 tip to join to the A3 air box?
  2. superkarl
    superkarl MAN OF STEEL
    9,611
    2,481
    you do realise its not made for an A3? dont you?
  3. <tuffty/>
    21,897
    4,206
    Keep up dude he's doing a K04 conversion lol
  4. superkarl
    9,611
    2,481
    pfft, so earlier on in the year.
  5. Prawn
    11,677
    3,676
    Phil, im afraid to say mate, you just need to figure it all out and follow the routing for each pipe.
    Your a3 airbox will be no good to you anyway, as your 80mm maf for the ko4 won't go into the a3 airbox anyway.
    The fittings on the tip are self explanitory, as each port is a different size and only the correct bit will fit!
  6. phil miller
    1,211
    166
    Thank you mate, thats spot on, after i posted i had another look and felt a little silly posting up as the hockey puck and DV can only go one way and the pipe that went to the bottom of my Ko3s tip can on the S3 tip, so thyen the N75 can only go in one place lol
    Think i better buy a Jetex cone right about now TBH lol
