  1. davidniclee
    davidniclee Member
    96
    would a ko3s fit strait on to my a3 1.8 20v turbo agu and would i need to change any other parts thanks dave
  2. quattro1
    quattro1 Member
    639
    yeah you'd need a different tip but if i were you id fit a forge silicone one while your changine the turbo
    other than that it will bolt straight on mate, obviously you'd need a remap
  3. davidniclee
    davidniclee Member
    96
    thanks for that wheres the best place for a remap, iv heard of jabba but heard there ****, and revo not heard anything bad about them so far where is the best place for a remap
  4. quattro1
    quattro1 Member
    639
  5. A3tell
    A3tell Member
    239
    as far as the k03s is concerned, it is a straight bolt on to our agu, but i think the outlet is bigger, so you WILL need a tip to fit it, be it forge/badger5/oem.
    and r-tech is deff the best place around for the remap, they r vag specialists and a gr8 bunch of guys. had mine mapped there last week!! i have been on the market for a k03s for a while, but they seem to be getting snapped up pretty quickly, and the ones that do get through get get quite expensive. good luck.
  6. takworldwide
    takworldwide Member
    158
    Does anyone know if the Badger5 3'' tip will fit the k03s/agu?
  7. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    It won't mate, gear linkages are in the way..
    Forge or Autobahn for us KO3s turbo owners
  8. takworldwide
    takworldwide Member
    158
    cheers pal, could do with someone developing a 3'' tip for the a3, some of the gains on the S3's look awesome!
  9. Reesy
    3,640
    148
    Bill has one on the go for his KO3s'd ibiza, and I think he might have cracked it, but it involves moving gear linkages and something else as far as I'm aware. I think I might just get a forge one, as I can't see a 3" one being available anytime soon.
  10. wayne1.8t
    wayne1.8t Member
    150
    Sorry to butt it!
    I'm thinkin of getting a forge TIP for my a3. How can I find out which turbo I have?
    It a AUM engine if that helps?
  11. takworldwide
    takworldwide Member
    158
    If you have a aum engine,you should have a k03s turbo.
  12. takworldwide
    takworldwide Member
    158
    I think the cheap and cheerful TIPs on eBay do the same job as the forge ones.does anyone know how much a forge TIP is?
  13. wayne1.8t
    wayne1.8t Member
    150
    Cheers pal
  14. wayne1.8t
    wayne1.8t Member
    150
    Just been lookin at some(TIP) around £130
    That's from dpmperformance
  15. davidniclee
    davidniclee Member
    96
    its about 3 hours from me but when iv got cash floating about will get it done, is it worth remapping a standard 1.8 20v turbo k03 what gains could you expect ,standard its around 150bhp and 155ft/lb i think so what would a map take it up to without moding anything
  16. quattro1
    quattro1 Member
    639
    wayne - it doesnt matter what turbo you have, a silicone one will fit both k03 and k03's no problems at all
  17. crazychris
    crazychris Member
    89
    i havent had it done yet but i keep speaking to the lads at r-tech and they're really helpful they specialise in the 1.8t engines and dont really touch anything else i think i spoke to wayne??? and he quoted me around 190bhp and 220ib/ft not sure if that is fly or wheel measurements, but that was on a completely stand a3 he said with induction and tip you could touch 200bhp trouble is after that k03 runs out of puff so its either ko3s time or hybrid/aftermarket, he quoted me £250 i think but it get three runs on the dyno full vcds check smoke leak test and a health check and wont map if its wrong, from what they told me and what i heard on here its a really through service and the lads are brilliant, its defo the place im goin as soon as i get the cash!!!
  18. wayne1.8t
    wayne1.8t Member
    150
    Cheers pal!
    Where is R-tech located? I'm thinking of a remap after I get a Forge TIPand 007p.
  19. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    Unit 17, Phoenix Business Park, Brindley Road, Hinckley, Leicestershire, LE10 3BY
