Ko3s fitting at tip fitting woes
Turboman-a3 Mar 26, 2011
  1. Turboman-a3
    Turboman-a3 speed thrills
    153
    Hi lads I fitted the ko3s today aswell as a tip BUT if anything it seems to have lost the boost a bit I've checked for leaks but can't find them i put a remapped ecu in the other day and was hitting 15-16psi but im sat at a smooth 12-14 without the feeling of being sucked in to my seat lol I wonder if it's the fact the map was on a ko3? any help is appreciated men
  2. Plunky
    Plunky Member
    522
    you'll want to get it mapped buddy, somewhere like R-tech are very good with the k03s on an agu lump.
    you may find the boost will be very spikey aswell
  3. Turboman-a3
    153
    But surely it should have more than 14psi also my dv is sort of fluttering what a headache fitting was lol
  4. Dani_B19
    9,343
    394
    Youll need to get i mapped, the map like you said is/was setup for a ko3 not a ko3s.
  5. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Audi's work on specified boost rather than raw PSI. So you may find the K03s gives the same power/performance for a low psi due to it being a bigger turbo.
    You should however get some increase in performance but it's likely to be less lag and a harder pull.
    Agreed a new remap on the k03s and you're Fmic will give you the best performance improvement but even so you can safely run the K03s on the map you have.
  6. Turboman-a3
    153
    Yeh I'm guna ring r-tech Monday and book in I think ur rights the 0-60 feels as good if not better just without the spike of boost I think I had to high expectations and was a little disappointed after 6 hours hard graft lol But I'm sure r-tech will put a grin on my face lol
  7. takworldwide
    takworldwide Member
    158
    Hi guys, finally got a k03s to do the upgrade on my AGU lump. just wondering if you guys have any advice on fitting turbo e.g new gaskets or special tools (part numbers would be great).
    Also thinking about upgraded TIP and De-cat but would i really notice the difference??? i know i need a new tip from a AUQ/AUM engine.
    any advice would be great
    Tom
  8. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    wouldnt the tip be the same? i know theres a slightly larger lip on the turbo (2-3mm diameter) but u could stretch that easy and it has the same outlets as ur engine used to have
  9. Turboman-a3
    153
    I used a agu silicone tip and it fitted easy and I didn't gave to blank any plugs off
  10. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    This should be all you need:
    k03 > k03s Turbo DIY / Fitting Guide (Mk4 Golf) - uk-mkivs
  11. takworldwide
    takworldwide Member
    158
    cheers welly i knew i seen a link somewhere.
    @turboman where did you source your tip from?
    thanks
  12. Turboman-a3
    153
    eBay mate just a cheapy and works beautifully mate
  13. Prawn
    11,610
    3,594
    the ebay silicon TIP's are remarkably good quality really, Nick at Rtech actually recommended I buy an ebay job for £45 rather than spend £120+ on a forge!
  14. Welly
    10,696
    129
    I would do the same, mine was great.
  15. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Do you have a link to the one you had mate? I'm assuming the price of the forge one is because you are paying for the name?
  16. Welly
    10,696
    129
    I don't mate sorry, that was a LONG time ago now.
  17. Turboman-a3
    153
  18. Turboman-a3
    153
    Also if you where interested in a forge one pm S3 BAM and hel sort u out A bargain mate
  19. Reesy
    3,640
    148
    No problem mate, I'm assuming it was just a plain TIP though, might get one of the toyosports ones, as their FMIC's are pretty decent from what I've seen/read on here..
