knocking sound when going over potholes humps
anilkumar Aug 21, 2010
  1. anilkumar
    anilkumar Member
    66
    MY a3 has strated making a knoking sound when going over humps and pot holes there is a slight noise coming from the front but somtimes get a very loud knock from the back i have changed the rear top mounts the arbs look ok has any1 else had this problem
  2. colicabcadam
    colicabcadam Guest
    bit silly, but are your tyre pressures correct?
  3. anilkumar
    anilkumar Member
    66
    yes there correct could this knocking be caused by worn rear axle bushes
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    What sort of A3, T Sport or Quattro?
  5. ChrisSThree
    ChrisSThree New Member
    14
    Check that the front ARB plastic collars (assuming it's an original ARB) haven't fallen apart. All your exhaust mounts are ok as well?
  6. anilkumar
    anilkumar Member
    66
    its a 2002 standard a3 tdi 130 SE arbs have been checked and seem ok
  7. mattyboy199
    mattyboy199 Well-Known Member
    1,897
    31
    wish bone bushes
  8. Sandip
    2,456
    99
    Shocks
  9. anilkumar
    anilkumar Member
    66
    ok thanks il have to have a look i have asked a VAG speailist and he thinks rear axle bushes but will ask him to check the other stuff
  10. Lloyd149
    Lloyd149 Member
    93
    Knocking sounds are usually bushes, previous car was a Ford and that is their most common problem.
  11. anilkumar
    anilkumar Member
    66
    the problem was rear axle bushes
