Knocking sound on full left lock
Ian_tdi Apr 22, 2012
  1. Ian_tdi
    Ian_tdi Member
    306
    As title, any ideas? Only started yesterday and only when on full left lock so obviously at low speeds only!
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,805
    10,907
    ​Possible a gater issue. :)
  3. rob_watti
    rob_watti Member
    62
    sounds like the symptom of a driveshaft outer cv joint. Where are you located? If your anywhere near skipton in North Yorkshire we could take a look for you. If not any workshop should be able to easily diagnose the fault.
    Rob
  4. Ian_tdi
    Ian_tdi Member
    306
    Hmmmm really? I had the cv gaiter replaced at mot (only 6 months ago!).
    The car is quite low, would this lead to excessive gaiter wear?
    Many thanks
  5. rob_watti
    rob_watti Member
    62
    the gaiter only covers the joint. If it's the joint thats worn/ knocking that will need replacing as well. Low cars do go through C.V joints quicker than normal.
    Regards
    Rob
  6. Ian_tdi
    Ian_tdi Member
    306
    Ok cool many thanks will get it checked this week.
  7. NHN
    29,577
    1,779
    Also racks have been known to cause the same issue usually only on left full lock, hence audi have a plentiful supply of the buggers always.
  8. PhilM81
    PhilM81 Quattro, bring on the SNOW!
    84
  9. NHN
    29,577
    1,779
    Is it on full lock?
  10. PhilM81
    84
    Ian, did you manage to fix this??
  11. Ian_tdi
    Ian_tdi Member
    306
    My mechanic looked at it last week, said its the outer cv joint, getting it done this week.
  12. Ian_tdi
    Ian_tdi Member
    306
    Sorry that meant to say out cv joint gaiter.
