Knocking & rattling
NATE6874 Aug 21, 2011
  1. NATE6874
    NATE6874 Member
    35
    I've got an A4 B5 AVANT on a 1997 plate. The front end is knocking and rattling on uneven surfaces and seems to be getting worse. I mentioned this to a mechanic friend of mine when I had the off side front drive shaft replaced (the inner cv joint was broken and mangled up) he had a look at the suspension and subframe and said it was fine. It flew through MOT in JUNE with only one advisory of off side rear wheel bearing has a little play in it. Any ideas what it could be????
  2. Bradderz_1988
    3,951
    235
    I'd be giving your coil springs a once over as they can go at any given moment !
  3. Oranoco
    Oranoco Well-Known Member
    3,911
    390
    Suspension arms, they can be a right Bugger for finding the one dudd one that's causing the problems
