Knocking noise since lowering
SteveU Oct 27, 2007
  1. SteveU
    SteveU New Member
    As the title suggests, since I lowered my car 60mm on 18's I've had an annoying knocking noise over rough ground from the front suspension. I'm suspecting the suspension arms are to blame but has anyone else had this and if so, which arms are most likely to be the culprits? I should mention that the ARB C-links and the front lower arms are new so that rules them out!! Still 6 arms left though :keule:
    Mine's a '96 B5 Saloon 2.6 FWD model by the way.
    Cheers,
    Steve
  2. andybnwc
    andybnwc Member
    752
    top bushes most probably lowering just puts extra strain onto them ive got the same at the moment just waiting to get the powerflex fitted
    If however both are knocking the top mounts on the suspension may be to blame
  3. macca
    macca Member
    525
    usually it is the ball joints on the arms, check the two upper ones especially for play, i thought mine was the ARB links at first then when i did my suspension change it was obvious that the upper rear balljoint had died. i replaced the upper top mounts as well, but i can't see that these would wear very easily on the a4's.
  4. Biglockie
    Biglockie Aye you know it makes sense
    1,032
    There is a group buy in here for the powerflex bushes for the front end
