knocking noise, left front wheel
addyboult Apr 30, 2012
  1. addyboult
    addyboult New Member
    How do, my s3 has developed a knocking noise from the front left wheel, not the top mounts had them done recently, i suspect the drop links as it only occurs when turning right when the weight of the car shifts that way, anyone else had this issue, just wondering if its the right thing to be looking at!
    addy
  2. LoopTrooper
    LoopTrooper Member
    Usually the easiest way to find out is jack the car up then pry along all the bushes. If something like that has gone or a ball joint you will be able to see the excess movement.
  3. addyboult
    Had it up earlier and the only thing that moved and rattled was the driveshaft, could be the cv joints?
  4. egesford
    egesford Member
    346
    i have the same problem, am guessing driveshaft
  5. LoopTrooper
    LoopTrooper Member
    Guessing you can't see a split boot or anything?
  6. addyboult
    I didn't have time for a full look, but Im guessing as its the only part i could move around by hand , and it did slightly replicate the noise, so going to block change inner and outer joints and reboot and grease them, driveshafts work out at about a ton each don't they?
  7. AJD S3
    AJD S3 2nd Gear
    107
    15
    I had a similar issue on my S3, turned out to be the bracket that the ARB bushing rests on had snapped clean off. The play in the ARB was huge, causing a nasty knocking sound. Easily rectified though, just fitted a new bracket and bushing, and all sorted.
  8. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,209
    2,029
    It's more a clicking noise for cv's,droplink is more of a clunking iirc.
  9. addyboult
    The noise only comes when under acceleration, as soon as i lift its gone, that's what's made me suspect the cvs on the driveshaft, that and the play in it i felt too
  10. jitvv
    jitvv Active Member
    198
    58
    Hi Addyboult,
    I seem to have the same problem as you, did you ever get to resolve this?
