Knocking feel through the steering wheel.
nickelvery Jun 17, 2007
  1. nickelvery
    nickelvery RS4 B5 380bhp
    545
    :jester: When you move the wheel slightly from side to side you can feel a slight knocking. My friend mechanic had a quick look and seem to think the uj thing needs changing. (How technical does that sound.) I looked at some other treads and it seems that the whole column would need changing. Any ideas people?
  2. s3ollie
    s3ollie Member
    762
    yeah its just the UJ thats f*cked but as usual you cant just get that bit!!
    I had the same and had to change the column got it from vagparts and twas about £225 audi wanted about 350.
    Id say to check its not your rack with the play before buying a new column though
  3. s3ollie
    s3ollie Member
    762
    there is an adjustment on the rear of the rack so might be worth giving it a tweak see if that helps too
  4. rodenal
    rodenal Active Member
    1,992
    You can also have most UJ's repressed - not sure how much of a permanent fix it is tho, or what the cost would be.
    Mine has done if for two years now ive still not got round to sorting it
  5. nickelvery
    545
    Is this easy to do? Any pics?
  6. rodenal
    1,992
    If its the adjuster i think it is then it sits right in your drivers footwell at the bottom of the column - 13mm iirc just turn it slightly and try turning the wheel to see if it helps
  7. s3ollie
    s3ollie Member
    762
    you couldnt really get the uj changed on mine as they press the metal around over it so it would have damaged or cracked it if id press it out, done so you have to buy a whole new unit i suspect.
    The adjustment is on the rear of the rack below the drivers footwell. youll need to jack the car up and use an extension bar between the subfarme and footwell. 17mm i think on S3
  8. s3ollie
    s3ollie Member
    762
    I think the 13mm bolt that rodenal mentioned above is where the column joins the rack and thats def worth a look to see if its loose as rodenal says:thumbsup:
  9. nickelvery
    545
    I have had a good look by taking the covers below the dash off, and there is a clear amount if play in the top UJ. Put a little grease on but it makes a small grity sound when moved. I'm hoping that the 13mm bolt at the bottom just releases the column then removing covers near the steering wheel. Any advice would be greatly recieved.
  10. nickelvery
    545
    I took the covers off to look at the steering column and I think I have found the offending article. There is a slight amount of play in the top UJ I think. If you pull the column down then move the steering wheel it the knock is no longer.
    I'm thinking about doing it myself and replacing the column. As you see with the bottom photo you can undo the bolt and hopefully get the column off at the bottom end, it'll be very interesting getting the top bit off and then re fitting it all.
    Any tips woud be great.
  11. Stewart
    Stewart Member
    705
    10
    If you do change it yourself, ensure that you get the new column in EXACTLY the same place as I can see the bottom uj is on splines.
    If you don't, the steering wheel will be off centre and then the steering angle sensor will go nuts, throw up errors in VAG-COM and then start kicking the ABS in around faster bends (because it thinks you are going round a sharper corner faster than you actually are)...
  12. HTC
    HTC Active Member
    3,428
    9
    The UJ has a missing spline and cut-out for the bolt so it only goes one in one position.
  13. nickelvery
    545
    Cheers guys. Most helpful.
    Do you know the best place to buy one?
  14. rodenal
    1,992
    Unfortunately only audi will sell you a column
    Only other option is ebay/scrappy but thats a bit risky as the new one could quite easily be goosed too
  15. s3ollie
    s3ollie Member
    762
    got my column from vagparts.com for about £225 audi wanted 380+vat or somthing
  16. jm-baker
    jm-baker Member
    230
    I have a knocking top UJ on my steering column.
    Does the TT share the same column does anyone know? They seem so expensive!
