Knocking at the rear
Digga Feb 21, 2006
  1. Digga
    Digga New Member
    12
    Only had my A3 1.8T for just over a month but I've started to notice a knocking sound coming from the rear of my car.. Sounded like something in the boot rattling about, removed everything from the boot to make sure, still knocked. It only happens over small bumps in the road, going over a large pothole or such doesn't reveal anything obvious.. I'm starting think it's the suspension. Can anyone give some idea as to determine the cause..
    Digga
  2. rickparmar
    rickparmar va va voom
    2,272
    check your exhaust mate
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    mine does that a bit, I think its my latch that is causing it as there is slighty movement in it, even when shut right. Only does it over very bumpy roads.
  4. chrisb
    chrisb Member
    141
    Mine has driven me mad with this. I now know what it is, but can't see how to stop it: it's the folding backrest of the rear seat (the passenger side in my case). If you fold the backrest it stops. I've adjusted the rubber stop, and put foam there, but no good so far.
  5. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    35
    i've had a knocking sound - and i was told it may be the rear suspension bushes... i'd already checked the exhaust & it seems solidly mounted.
    it does sound like its coming from the underside of the car... its pretty loud & metallic sounding?! i'm not sure if its audible outside the car, but it seems like it & is embarrassing!
    any ideas?
  6. Digga
    Digga New Member
    12
    hmmmm... thanks for the replys peeps.. You've certainly given me some food for thought.. Thought it could be my rear off side suspension strut as it doesn't rebound after pushing it down as quickly as the near side and it gives quite a squeak (bushes?).It's not my exhaust either, I'll have to check the rear seat and boot. Mine does sound like its coming from inside the boot..
  7. darnich
    darnich Member
    106
    I hear a knocking sound when I hit bumps but I know it is due to the larger exhaust hitting on the trailing arm of the rear suspension
  8. HTC
    HTC Active Member
    3,428
    9
    My rear seat knocked. It was where the bottom of the backrest attached.
    I wrapped a small amount of electrical tape around the spindle which cured it.
    Then I got a rattle from the same area. This was the one of the rear headrests.
    To cure that all I did was pull out the headrest and then bend the arms apart very slightly so if fitted tighter.
    Nice and quiet cabin now.
  9. s3bow
    s3bow Member
    378
    ARBs are known for fracturing. Rear one on mine is creaking well at the moment.
    Chris.
  10. JB_A3_Turbo
    JB_A3_Turbo Member
    98
    I get a creaking sound from the rear of my A3 (drivers side) when the car tilts most noticible when manouvering at slow speeds eg on slopes, up and down lowered kerbs etc...
  11. Digga
    Digga New Member
    12
    s3bow: Anti roll bars are known to fracture??? Don't like the sound of that one bit.. Doesn't the whole Rear axel have to be changed for the rear roll bar, least thats what my haynes manual tells me..
  12. s3bow
    s3bow Member
    378
    Not on the 4wd cars. Drop the rear exhaust box and some heat shielding. Front involves dropping the subframe.
    Not sure about the 2wd though. Rich on here will be able to tell you though.
    Chris.
  13. chrisb
    chrisb Member
    141
    [ QUOTE ]
    [/ QUOTE ]
    You might just save my sanity with that bit of info.
    [reaches for electrical tape]
