Knock Sensors
Barks Jun 28, 2012
  1. Barks
    Barks Member
    337
    Hello,
    Does anyone know if there is a difference between the APY and BAM knock sensor output voltages?? I believe the PN's to be different.
    Dave
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    You still running apy ones then?
  3. Barks
    Barks Member
    337
    Yep sure am, It just crossed my mind last night.....
  4. beachbuggy
    1,931
    202
    Yes they Definately need to be changed. Not sure why but they need to be changed, but when I asked I was told the frequency was different due to different chip sets on the ecu.
  5. Barks
    Barks Member
    337
    mmm, might be the reason for the low CF..... off to ebay.
    Any wideband AMK, BAM sensors???
  6. beachbuggy
    1,931
    202
    They are the ones without wires, would have thought amk and bam would be the same. Mine cost £13 each new I think for a patent part. I know it's a risk with something as sensitive as knock but they seem to work fine.
  7. Barks
    Barks Member
    337
    Cheers, I will have look
  8. Barks
    Barks Member
    337
    BAM knock sensors on order, I will do a log before and after changing from the APY ones. Then we will know if it required for a APY to BAM wideband conversion.
