Knock sensors
AudiiduA Mar 21, 2011
  1. AudiiduA
    AudiiduA Member
    359
    Hi all, had my s3 on vagcom today, needed a new MAF and a knock sensor! how hard is the knock sensor to fit? pics would be good as cars gone into limp mode:(
  2. finesse
    finesse Active Member
    2,805
    can not find a pictures now but its around the inlet mani
  3. AudiiduA
    AudiiduA Member
    359
    Mines AMK, i believe theres 2?? is this correct? i know where they are just looks a pain....
  4. imraans3
    imraans3 Member
    34
    Pm'd ya matey
  5. Agric04
    Agric04 Active Member VCDS Map User
    290
    This may or may not help you. I had a real issue with my knock sensors about 2 years ago. Vagcom kept identifying one of the knock sensors as faulty. Had the car at various garages trying to resolve issue and changed the faulty knock sensor twice before giving up and taking mine to the stealers. Turned out that the faulty knock sensor for me was the one that vagcom wasn't picking up as the good knock sensor was doing it's job and logging the fault. So if you change your knock sensor and still get faults try changing the other one too. Worked for me.
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Can also be wiring related, so check out the connections, and look for broken wires before parting with cash.
    Knock sensor is easy to change if you need to - they are both on the face of the block.
    Make sure you do them up to the correct torque - 20 nm rings a bell but don't quote me on that.
  7. AudiiduA
    AudiiduA Member
    359
    Its coming up with no 1 sensor! is that the left or right one??
  8. LD3
    LD3 Member
    98
    Mine had a knock sensor fault-turned out to be some wriring and not the sensor itself.
