Knock Sensors and Timing Pull
Alex C
Well-Known Member
Lizard, Cornwall
Background:
Standard Engine S3 8L AMK
Fault Code: EGT sensor - being fixed next week
Rattely clacking head: I think this is either cam chain or tappets - hopefully being fixed Wednesday next week
Anyway, today i went out and logged it, i didnt do any hardcore 100% load 0-redline pulls just drove it around normally in traffic in and out of town logging.
I knew already i was suffering from timing pull so i logged [003, 026, 020]
block 26 are the knock voltages and block 20 is the timing pull block
Here is a plot of timing pull against engine speed:
so its cylinders 3&4 that are getting timing pull
But when plotting the knock sensor voltage against engine speed:
it is the knock sensor on cylinder 2 that looks abnomal
Am i right to be confused here or should i just travel hopefully?
knock voltages alone dont tell the picture..
CF correction resultant accounts for the windowed knock regitration not just voltages.. which swing about a lot... I've seen 30v! and no CF
thanks Bill,
I know i don't have the logs posted but what might cause timing pull only on cylinders 3&4 on part throttle?
if you have an egt fault wont your fueling be abit off.
mine was, i was very rich for quite a while.
That fault might have something to do with your CF. just a thought, but once its fixed then do your logging again to see if there is any change.
Thanks Karl. yeah i will do, i am hoping that either the EGT or renewing the timing chain will fix it but i figured that both of those faults would affect all four cylinders rather than just the two.
Maybe its tappets on those cylinders or maybe both of them coincidently have problems with piston rings?
