Knock driving me crazy!
MyCarling Nov 14, 2013
  1. MyCarling
    MyCarling New Member
    17
    Hi all. Been a member for a few months now and have never felt the need to post for help but I am well and truly stumped.
    I have got a slight knock coming from the front drivers side. It not a loud knock and only happens while going over uneven road. I can hear it while going slow but obviously the faster I go the louder the engine gets so I no longer hear it. I have replaced pretty much everything I can think of and I don't know what to do next lol. Thank you for any advice you can give.
    1998 a3 1.8t AGU
    Replaced both wishbones
    Replaced both wishbones bushes to poly
    Replaced drop link arms
    Replaced strut top mounts and bearings
    Replaced anti roll bar bushes
    Replaced both drive shafts
    Additional mods
    Oil catch can
    K04-001
    2.5 inch turbo back exhaust
    Forge tip
    Forge recirc dv
    Remap as soon as this knocking noise is sorted and fmic installed :)
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Brake pads rattle? My rear ones were doing it for months before I found it.
  3. bazf
    bazf New Member
    10
    Loose arch liner or belly pan?
  4. MyCarling
    17
    Brake discs and pads been done. And there is no plastic belly pan on it. It sounds like a dull metal on metal. Its not far off the same sound as a wishbone bush that has gone bad?
  5. bentescort
    bentescort New Member
    I recently bought a 2002 S3 and had the same knock over rough ground at low speeds.
    After changing a few bits and pieces I discovered that the drivers side front shock was the culprit. Not only did it have no rebound left in it, the damper was rattling about in the shock body.
    A pair of new dampers later and the jobs a good 'un.
    Cheers.
  6. MyCarling
    17
    Thanks mate. I will check that out when I get back from lodging. Cheers
  7. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,823
    3,479
    Track rod and ends?
  8. MyCarling
    17
    I have checked them and they are fine
  9. Grant-s3
    Grant-s3 Nogaro Blue
    74
    Have a look inside the engine bay incase anything is loose and knocking about. Then jack it up, remove the wheel and gently tap away with a rubber hammer and listen.
  10. ticketyboo90
    ticketyboo90 Member
    30
    Wheel bearings?
  11. MyCarling
    17
    I checked the wheel bearings last weekend and they are ok
  12. Gops
    3,188
    647
    I know this sounds obvious.. But is your wheel tight? Mine was slightly loose and I had exactly the same symptoms.. I have no idea how it came loose but I guess it worked its way loose somehow..
  13. Gops
    3,188
    647
    Ow and make sure the DV isn't hitting the strut brace.. Happened to me and drove me completely insane for months!!!
  14. MyCarling
    17
    I haven't got a strut brace mate. Dv not hitting anything. All wheels are tight. I didn't change all these parts in one go so the wheels have been on and off numerous amount of times lol
  15. p1tse
    p1tse Member
    796
    24
    Cv boot? I had this before
    Does it happen when turning at low speed?
    Try putting it on full lock and have a look to see if cv boot is split, you'll probably see some gunk
  16. MyCarling
    17
    Its not a cv boot mate. I have replaced both drive shafts with new boots. It happens when going straight and when turning
  17. jojo
    28,823
    3,479
    I checked mine, and they were fine too! but on a Hunters 4 wheel alignment machine, it detected 0.1mm play on the passenger side steering rod!! Changed to a new one, and knocking disappeared.
  18. Tooks
    Tooks Active Member
    753
    29
    I would second what jojo said, my car was making very similar recently. All new dampers/springs/drop links/top mounts and roll bar bushes which I thought would sort it, but to no avail.
    I replaced the track rods and ball joints more out of desperation than anything, and the noise disappeared. The stuff on there had sailed through the MOT a few weeks ago too, but must have been some play in there somewhere.
    Not sure ultimately whether it was the track rod ends or ball joints, but I did notice a metal rattle sound when I tapped the steering rack arm on one side with a rubber mallet. When I do the same post change, there isn't a sound.
  19. MyCarling
    17
    I will replace them then when I get paid next... I had just persuaded the wife to let me fork out on new shockers and coilovers :( lol
  20. Pubemammal
    Pubemammal Active Member
    522
    114
    43
    I have this same knocking, also an A3 8L 1.8t. It has starting happening ever since I wound the coilovers down a couple of CM's. Let me know how you get on :)
  21. Pubemammal
    522
    114
    43
    Also, when going very slowly and lightly putting foot on the brake, can you feel it through the brake pedal?
  22. MyCarling
    17
    I dont feel it through the brake pedal mate
  23. RobinJI
    RobinJI Active Member
    176
    26
    Yep, I'd second track rods/ends, I take it you did the lower ball joints along with the wishbones? Failing that it could be worth adjusting the steering rack.
