Knock/clunk noise over bump,think it's the o/s rack end??
millwrx Feb 1, 2010
  1. millwrx
    millwrx Member
    223
    hi i have a 51plate 2ltr petrol avant,has 168000 on the clock and drives like new,the only thing it has is a knock from the o/s/f when i hit a bump in the road,have jacked it up,no play in any of the suspension joints etc,i can get the knock if i grab the wheel and really work the rack from left to right and a slight bit of play,are the ends of the rack replaceable as i have been told they are,had a quick look on ebay and have found some rack inner tie ends??anyone else had this???
    cheers
  2. millwrx
    millwrx Member
    223
    anyone??????
  3. simon.m
    simon.m Active Member
    2,747
    can be your track rod ends or ball joint i hand a knocking and it was both of them.
    im told knocking is very common on audis
  4. DAMO1.9TDI
    DAMO1.9TDI 130BHP+,A4+ K & N Filter, Tuning Box.
    34
    :banghead:I'm having the same problem 52 reg A4 170K clock, Mine has jut got more noticeable after installing an FK AK Suspension Coilover Kit - Firmer suspension - hence the knocking has become more noticable and is drivin me nuts.
    This is what I have done to date : (after installing coilovers)
    Changed both upper arms, drop links & anti-roll bar bushes, took out both lower arms inspected bushes & ball joints, Changed Tie rods ends , inner tie rod ends fine, done this for both sides. The clunking is only getting worse, I am now thinking it the steering rack - Going to try the steering gear adjustment as described in the haynes manual on the steering gear, then the next step is to take out the steering rack and see where it goes from there- cost me enough £££'s already - no point stopping now.
    Anyone got any ideas before I end up having to re- mortgage my house!!!!
    Signed :
    Desperate :banghead:
  5. stuhow3361
    stuhow3361 Member
    210
    14
    got the same fault exactly on my 1.9tdi avant with 93k on the clock.gave it to a friend of mine to service(he's a fully qualified audi master technician) and he could find no play in any of the steering/suspension joints but the noise is still there over bumpy ground.hope you guys find the cure since this is annoying me also.
  6. Broken Byzan
    13,237
    465
    Top mounts more than likely. They tend to show themselves after lowereing due to incresed load on the suspension
  7. paul20v
    paul20v Audi fanatic
    1,113
    Who told you that mate , non of my audis have ever been clunky they have always gone down the road really nice and quite suspension wise even back as far as my 1974 audi 100GL
  8. DGT
    DGT New Member
    21
    Im having the same issue 2002 A4 tdi130 avant 120k. Replaced all worn steering arms, drop links, tightened all subframe mount bolts, taken brakes apart and rebuilt, had 2 audi technicians look over it. Still getting a knocking from the OSF..driving me mad, even thought about getting rid because of this problem and the inevitable DMF problem im expecting.
    Toying with the idea of changing out the engine mounts and maybe the struts, but i suspect its something more sinister...bloody over complicated design!
    Ive only heard of this problem on TDI versions :uhm:
    *edit* A4 B6 top mounts have no bearings to wear out
  9. Broken Byzan
    13,237
    465
    Bearings do not wear out, but the rubber can degrade and casue too much movement over bumps etc
  10. simon.m
    2,747
  11. DGT
    DGT New Member
    21
    But the rubber is under compression from the considerable mass of the car. I questioned this myself to a couple of very experienced VAG guys, they had never heard of top mounts causing problems.
    Have you ever cured a knocking problem by changing the mounts?
  12. donsajid
    donsajid Member
    110
    i'd love to know the answer to this too..... 02, 2.5 tdi 117K miles and mines got the same knock as described aove
  13. DGT
    DGT New Member
    21
    Found a leaking shock absorber..changed with Bilstein B4's from euro car parts @ £48 ea..problem solved car is now peachy V happy especially as noone i spoke to said it could be the shock as theyre not prone to breaking...found that the car has already had replacement OEM shocks..2 sets of shocks in 100k miles..heavy beast!
