Knackered engine mount?!
essee May 5, 2003
  1. essee
    essee New Member
    14
    Got a hell of a squeaking when I stick her in reverse and lift off a little with the handbrake on. Plus, driving along through the gears as normal, but lift off the throttle in 3rd in the high revs and the whole car shudders until I change up... must be the engine mounts, right?
    Shudders is the wrong word, more like jerks!
  2. mramage
    mramage Member
    516
    Never heard of that happening to an A3/S3 before? Could it be something more simple? Doesn't sound good anyway /ubbthreads/images/graemlins/frown.gif
    Anyone had experience of this kind of thing?
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    not heard of it on an A3/S3 yet but have seen it a few times - the car seems to lurch off the mark a bit. You could find a pal and pop the bonnet, then get him to watch the engine as you try to move off with the handbrake on and see if the engine 'lifts'. You may need to be a bit heavy with the throttle and quick with the clutch, just make sure you dont leap foward and knock your (ex?)pal over /ubbthreads/images/graemlins/grin.gif
  4. Mo-S3
    Mo-S3 Member
    706
    Actua;;ly i have heard of 1 case of an S3 having its mounts replaced coz the rubber in them had failed for some unknown German reason ! There are 3 mounts to look out for:
    There are 2 either side of the of the engine ie 1 on each side and the 3rd is under the car which is more of a gearbox mount which is designed to supress gearbox movement.
    Check if u can for perished rubbers if u can even manage to see them which i doubt judging by how well they are covered.
