Key fob will not lock or unlock
m.c. Dec 13, 2012
  1. m.c.
    m.c. New Member
    A4 Cabriolet, B6, 52 reg.
    The other day my fob stoped locking or unlocking the car, now i have to open with the key.
    The central locking works from the buttons on the door once in the car and the lights blink when locking / unlocking with the key.
    I have had the fob checked for a signal and was told it is ok.
    I tried to rematch the key to the car following the methods on the forum but no change.
    Any other ideas of what could be causing the problem, Cheers.
  2. Jp-tqs
    Jp-tqs Member
    183
    Tried replacing the battery? Low battery could be strong enough for a signal but not enough power to activate central lacking?
  3. Artimus
    Artimus Shortback
    2,016
    485
    I tested an option in VCDS that when you set the car to Transport Mode, it disabled the remote locking, along with 1 or 2 other things. Exit Transport Mode returned it to normal. You haven't had it on VAGcom recently have you?
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    lock the car and leave it until the hazard light goes out
    then press unlock on the fob if the hazard lights up it is getting the signal but not unlocking the doors
    mine did this and I had to disconnect the battery for a few minutes then reconnect and all was well
  5. leonwilliams
    leonwilliams Member
    55
    Hi i had same problem with my fsi lights flashing but no sound . i put spare key in ignition. other in door pressed open 4 times . then again. works fine now.
  6. Jay85
    Jay85 New Member
    27
    Mines intermittent. Ocassionally doesnt work. Fuses? Not sure whether central locking is fused?
  7. Artimus
    Artimus Shortback
    2,016
    485
    mine miss fired once last week! hasn't done it since and I pit it down to either a lowish car battery (now charged) or the receiver didn't pick up the signal. :shrug:
  8. docurley
    4,071
    85
    Just put key in ignition turn on (dont start) press lock and open button and all should be good if the battery is not dead.
  9. demus
    demus Fire in the hole..
    355
    19
    Mine has done this a couple of times, tried all the usual things of holding lock / unlock, in door, in the ignition etc... nothing worked.
    For some reason the car loses the code and it all needs re-coding, Audi charge about £40 to re-program it....
  10. pbarlow0032
    pbarlow0032 Member
    167
    I've got the same problem with my spare, Demus can you just get this done at any Audi main dealer? I keep putting off sorting this, but I need to do it before I need it!
  11. demus
    355
    19
    I'm guessing you can yes, I'm not sure if the buttons on my key are anything to do with it, it used to work from a hell of a distance, now you have to be in spitting distance.. batteries all ok.. It seems to do it if when walking to the car, I press unlock, it doesn't unlock due to the **** range, then press a couple of times more, it all gets out of sync and goes tits up.
    I only have the one key and keep telling myself I really should get a spare, still haven't got one!!
    Only takes about half an hour for the stealer to do.. if anything like mine they will also tell you that there are numerous fault codes stored, they have obviously read them, but won't tell me without another wad of cash, twats...
    Got VCDS and no codes were stored !! (Oh, and that it was allegedly running rough ??)
    Anyway rant over, check on here, there are some clever guys with the full VCDS and could probably do it for you cheaper than the stealer, sorry I mean main dealer...
  12. stu_m
    1,440
    you dont need it recoding at the dealer it will more then likely be the fob thats working loose and loosing contact with the battery
    Open the fob and bend the battery pins out slightly loads of us had the same problems on here and did this and all has been fine since
    do a search
  13. demus
    355
    19
    That didn't work with my bugger unfortunately... I did wonder if the antenna in the car was ok, don't suppose anyone knows where it is ??
  14. Artimus
    Artimus Shortback
    2,016
    485
    The receiver is by the centre speaker on the dash, where the flashing red LED resides
  15. Inertiauk
    Inertiauk Active Member
    574
    29
    audi have been pulling your pants down its really easy to do you just need 2 keys (1 doesn't have to be a remote key)
    1) Take the key you DO NOT want to program and put it in the ignition. Turn it one click forward.
    2) Close and lock the drivers door with the second key.
    3) On the second key (the one in the drivers door) press the 'UNLOCK' button ONCE only. The lights will flash on the car, but the doors will remain locked
    4) With the second key still in the drivers door, unlock then lock the door again.
    5) Pull the key from the slot and test remote functions.
    6) Open drivers door, remove key from ignition.
    sstevens2 likes this.
  16. demus
    355
    19
  17. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    you will need SKC to code new key to car with vcds , you may have it on small tab with your handbook/key.
  18. Inertiauk
    574
    29
    the second key needs to be coded to the cars immobiliser system which does need to be done by a specialist. However there is a way around it if you don't have a second key.
    get a plain key and have the blade cut, sit in the drivers seat with the window down and the 'cut but not immobiliser programmed' key in the door outside.
    Put your original key in the ignition and turn to position 1.
    either have a friend help or reach our through the open window and lock the car using the 'cut but not immobiliser programmed' key.
    press unlock, lock, unlock on your original key, then remove it from the ignition. Remove the key from the door and test your fob, it should be working.
    Hope this helps.
  19. pbarlow0032
    pbarlow0032 Member
    167
    My spare key doesn't work as a remote but does open and lock the car in the door lock, and does start the car. I put a new battery in the spare key when I bought the car (a few months ago). Should the process InertiaUK mentions above work? I might have another fiddle with the battery pins (cheers STU_m).
  20. pbarlow0032
    pbarlow0032 Member
    167
    Right, tried pulling the pins out a bit, battery is definitely making contact. Tried battery both ways up too just in case. Nothing at all happens when I press the unlock/lock button. No lights flashing etc, no locks unlocking! If I read the earlier posts correctly, it should still make the alarm lights blink evn if it isn't opening properly?
  21. stu_m
    1,440
  22. Inertiauk
    574
    29
    You have 2 keys for the car, sync it as in the first post I made above .
  23. Stu!!!
    Stu!!! Member
    60
    I've had the same problem twice now, without knowing the exact reason it stops working, in my situation, its been related to the antenna / receiver for the fob.
    If you go into the boot, and simply try pressing the key fob in a few random places, hopefully, it will receive the signal and all will be well again - mine just works as per norm now :)
  24. pbarlow0032
    pbarlow0032 Member
    167
    Inertia, I tried doing exactly what you describe in your first post, but when I press the unlock button on the (non working) key, there is no light flash. Am I missing something obvious?
  25. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,218
    161
    I recently had this. Took the car battery off, put it back on. All good.
  26. glenandem
    glenandem Active Member
    679
    31
    same here with my spare key,tried new batts and all different ways of coding and never get flashing lights?
  27. Stu!!!
    Stu!!! Member
    60
    The booster / Antenna for the fob / signal is in the boot, if you move the fob around the boot whilst pressing either lock or unlock etc, it will pick up a signal again.
    This has worked everytime... resyncing, disconnecting battery etc just didnt work ...
  28. stu_m
    1,440
    Could peoples problem be broken wires between the boot and main body?
  29. leonwilliams
    leonwilliams Member
    55
    Hi thats a strange one if it works in the boot but not outside the car could be a reciever problem, like i said earlier mines just stopped working both fobs..lights where flashing no sound i got in car turned ignition on and it stopped..i checked the forums and it just said open drivers window, put one ket in ignition turn but dont start other key in door press open 4 times lights should flash, then do it again and that should be it..i had to use key when it went on one i was like wtf....but its fine now both keys work
    can you not get someone with vag-com in your area to check for error codes
  30. 06A4Cab
    06A4Cab New Member
    Thank you for that information, it worked a treat... on the 2nd go.
  31. norris_309
    norris_309 Member Audi A4 Audi Avant Owner Group
    207
    17
    Just to add to this, I had a problem with my remote key not working.
    Just in case... have you looked in the cars handbook for the re-programming method?
    I tried the battery which didn't solve it & then looked in the handbook for the car which gives a step by step instruction on how to re-program it to the car using your other key (assuming you have 2) I remember looking online and seeing several posts with varying methods mentioned..
    I know re-programming it has been mentioned above, but might be worth a look in case for some reason there is a slightly different method of doing it on your car?
  32. Potatopete
    Potatopete Member Audi A4
    32
    Just bringing an older thread back rather than starting a new one, as I now have the same problem.
    Key fob has stopped working altogether. I've disconnected the battery and reconnected, turned ignition on and pressed lock/unlock, put a new battery in the fob, and tried the fob in and around the boot. None of this worked for me.
    I'm guessing I'll have to try my local Audi garage, unless there's any final solutions I can try?
  33. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Anyone local with vcds to try reprogramming the keys
  34. joinerman
    joinerman Well-Known Member
    9,572
    291
    Press & hold the unlock button
    Insert key in ignition& turn on still holding the unlock button
    Hold unlock in the on position for two seconds
    Turn key to off & remove from ignition & release button.
  35. sstevens2
    sstevens2 New Member
    Thank you!!! This worked perfectly.
    Took me a couple of tries as I was in the "On" position which is the 2nd position even though you clearly said 1st.
    Inertiauk likes this.
