Key Fob problem - Not locking or unlocking
a3tazza Jun 13, 2012
  1. a3tazza
    a3tazza New Member
    Hi there,
    I have recently changed the batteries in the key fob and tried the re-sync option in the manual (I only have 1 key) as the key fob doesn't lock or unlock my Audi A3 2.0 Tdi 2004 model.
    The key still unlocks the car when putting it in the key hole but the alarm will go off when enter the car and only goes off if I put the key in the ignition.
    I noticed you can get a used key fob off ebay but I'm unsure on the part numbers.
    Can anyone give any advice what the cheapest way to solve the problem?
    Cheers,
    Craig
  2. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    resync it using vcds
  3. mike foster
    3,967
    If you buy a used keyfob off ebay you will need to get a new immobiliser chip to put in it unless you only want it to lock/unlock. Even then it would need to be coded to the car.
    Presumably your existing fob used to work properly ? If so then you need to re-synch it as said above.
    The red led does flash when the button is pressed I presume ?
  4. a3tazza
    a3tazza New Member
    Cheers for the replies.
    There is no LED flashing on the fob but it did used to work.
    Do I just go to Audi or local specialist to resync using vcds?
    Cheers,
    Craig
  5. mike foster
    3,967
    The LED should flash quickly every time you press a button. Are you sure you have put a new battery in the correct way round ?
    You should be able to go to any VAG specialist to have it re-synchronised if necessary.
  6. Ste_Nova
    1,223
    47
    audi will pull your pants down for that job
    find someone local in the vcds forum to do it
  7. a3tazza
    a3tazza New Member
    I have tried the battery both ways. Where is the led light? I have a 3 button remote key.
    It has a code of HLO 8P0 837 231.
    I've been quoted this on ebay...
    Hi,
    Yes I can supply the correct item, with a new Canbus transponder so it is ready to be cut and programmed.
    I am after £40 including postage for the item.
    Regards
    - remotefobcentre
  8. Ste_Nova
    1,223
    47
    ahh a no light key :(
  9. a3tazza
    a3tazza New Member
    That's the one!
  10. mike foster
    3,967
    Sorry - I was talking about the later shape !
  11. a3tazza
    a3tazza New Member
    I'll just get one off ebay with a new transponder, get a new key cut and reprogrammed to see if that does the trick, at least I'll have two keys then.
  12. mike foster
    3,967
    Before you do, may I suggest you get a quote to have it coded to your immobiliser. I think you may get a shock !
  13. NHN
    29,329
    1,708
    Dont waste your time & there are very serious security ramifications of using external parties for coding immo these days, stick with audi & also the megamos48 immo chip they use needs half programming anyway by germany to be able to do rest at dealership.
