kerbed alloy
Vito Jan 26, 2013
  1. Vito
    Vito Active Member
    163
    86
    Hi guys, I have kerbed two of my alloys but the damage is very little, does anybody have some advice on how to repair it DIY ,if that is possible. Thanks.
  2. southylad
    southylad Active Member
    544
    There will be loads on utube mate easy enough if just paint
  3. P_G
    P_G Active Member
    383
    95
    Is it on the diamond cut surface or on the paint? If the former live with it as you can't repair those without taling them to a refurbisher that does diamond cut polishing. If on the anthractite paint you may be able to patch DIY but it won't last.
  4. Vito
    Vito Active Member
    163
    86
    on the dimond cut, it`s right on the edge
  5. P_G
    P_G Active Member
    383
    95
    Unless you have diamond cut polishing gear I'd live with it until you need to refurb the whole wheel. Trying to polish it out will make it look worse.
  6. 45bvtc
    45bvtc Well-Known Member Supporter Team Cornflower Blue Team Daytona Gold Supporter Team Sahara Silver Audi RS3 Audi TT Audi A1
    4,384
    7,666
    Talk to: JP Alloys in Cannock, Vito
    The finish is a clear acrylic powder lacquer that has to be oven-cured.
    I've recently had three sets of
    Audi alloy wheels re-furbished by JP Alloys in Cannock (local for me) two of which were diamond-cut and were returned in a first class condition.
    And this may help: I believe JP Alloys now offer a collect and return service, providing a suitable container for each-way transportation of the wheel and tyre, and returned with the wheel and tyre balanced and ready to re-fit; check with JP Alloys for delivery times and costs.
  7. P_G
    P_G Active Member
    383
    95
    Wheel Specialist franchises also now have diamond cut finishing facilities so there may be one of them closer to you if 45bvtc's suggestion is too far away for your liking.
    Vito likes this.
  8. JonnyG
    JonnyG Active Member
    227
    67
    Whatever you decide ... don't leave it as it is, otherwise salty water will get into it and start to creep under the lacquer and give your alloys the dreaded white worm.
    As a minimum clean it up a bit with some wet sanding, polish and then put some lacquer back on it.
    http://i22.photobucket.com/albums/b308/RedRobin_05/WhiteWorm.jpg
    Vito likes this.
  9. Vito
    Vito Active Member
    163
    86
    god !! that`s a first to me, thanx for the advice Jonny G
  10. NHN
    29,576
    1,779
    Give N8 a sponsor on here a shout he can refurb wheels like nobody I know :)
  11. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    606
    I hate to say it ,but its true vito leave it too long and ......
  12. NHN
    29,576
    1,779
    Looks like a bimoto to me :)
    Kelza likes this.
  13. Kelza
    3,078
    606
    Hi nigel ,correct ,waters got under the paint lol they will be getting a refurb and they will show an appearance very soon :)
  14. CarrG
    CarrG Active Member
    261
    So you bought them back then??
  15. Kelza
    3,078
    606
    No carrg not me :)
  16. P_G
    P_G Active Member
    383
    95
    Or clean it up and apply 2-3 coats for G-Techniq C5 on it. Not a lacquer but a chemical sealant which is very durable until you do want to get it fixed.
  17. JonnyG
    227
    67
    Gtechniq C1/C5 is not too good on bare metal though :sorry: ... but better than nothing.
    Excellent on paint though ( I have C1 on my car)
  18. P_G
    P_G Active Member
    383
    95
    C5 is holding up well on the alloys on the diamnd cut faces, better in fact than it does on the paint in some areas which is a bit wierd. Might trry C2 whihc is sipposed to be a spray on wipe off version of C5.
  19. JonnyG
    227
    67
    The diamond cut part (with no kerbing) has lacquer on it, and C1/ C5 will work OK on top of the lacquer coat. Once the lacquer has been removed (from kerbing etc) it won't be quite as good.
    Gtechniq C5 Wheel Armour fail. - Detailing World
    I use C2 and C1.5 for topping up the C1. The new version of C2 is getting good reviews.
    The painted bits on the RS3 Rotors do not feel that glossy and has quite a a matt look. I'm finding them harder to keep clean than normal ... probably what P_G is getting at above .... anyone else finding this ?
  20. P_G
    P_G Active Member
    383
    95
    The satin finish on them does make it quite hard for stuff to bond to them. I ended up using Menzerna Power Gloss on them to take off what C5 was there plus refine the surface and then applied C5 again so fingers crossed it should work this time.
    Last time it was a bit patchy which I have never experienced with C5 before.
  21. Kelza
    3,078
    606
    Hi p_g try af mint rims or nanolex paint and alloy sealant :)
  22. Vito
    Vito Active Member
    163
    86
    I have been quoted £510 from W.R.C. in Bamber Bridge,Preston, to refurbish my 3 RS3 alloys .......That sounded pretty expensive to me and they said that they cannot diamond-cut just the edge of the wheel (where the damage is) all the wheel has to be done and then repainted !!!!!! Does that sound right to any of you ??? Or are they just trying to levitate the price ???
  23. NHN
    29,576
    1,779
    Did you even contact N8?
  24. Vito
    Vito Active Member
    163
    86
    Looking at the wheel, I cannot understand why do they have to diamon-cut where the titanium paint finish is !!!
  25. Vito
    Vito Active Member
    163
    86
    is N8 somebody on this forum? coz I haven`t found it.
  26. Kelza
    3,078
    606
  27. NHN
    29,576
    1,779
    Kowalski Details - Innovative Automotive Care
    Well known for his wheel work.
    You goto a very professional outfit like WRC of which I've personally seen there very good work & they advise you about the way they have to be done to get the best possible finish, which sounds right & you now dont believe them?
  28. Vito
    Vito Active Member
    163
    86
    45bvtc advised JP Alloys, I have been on their website and are charging £ 65+vat.
  29. NHN
    29,576
    1,779
    Yes but some standard prices dont include specific special jobs, like welding metal onto kerbed walls as such & cutting back to the original lines of the wheel, so for your wheel type, that may not be the full price once they see the wheel type, it takes a fair bit of time to repair some wheels overall.
    Not being funny but £500 to get your 19" wheel back to original state, considering its more than that for one new wheel from audi, isnt exactly expensive IMHO.
    Anyway, choose wisely considering the wheel & car, but I have seen wrc's work & I dont know them directly & its been very impressive.
    Vito likes this.
  30. Vito
    Vito Active Member
    163
    86
    Of course I totally agree with what you are saying, I saw today with my own eyes how fab their work looks, but I just want to make sure on what to do and where to go for the job and was looking for some advice as I have not had any experience before with wheels repairing stuff.
  31. CarrG
    CarrG Active Member
    261
    Depending on the damage to the diamond cut area I would assume all that area would have to be recut.
  32. P_G
    P_G Active Member
    383
    95
    Sorted it now by polishing the arms with Menzerna and then reapplying C5. Appears to have worked this time.
  33. P_G
    P_G Active Member
    383
    95
    Vito, contact Tony Gray at the Wheel Specialist in Newcastle and say that Graeme recommended you to him. He can Diamond polish the edges and has the Satin lacquer that the wheels are finished with as it was the first thing I did on the way home from picking up my car from new to see that he could repair the alloys (just in case). He may also be able to advise you if any of the local franchises can do what he does.
    Vito likes this.
  34. 45bvtc
    4,384
    7,666
    I've spoken to JP Alloys today (Pete Horton, hands-on owner/director of JP Alloys on 01543 503362) and Pete tells me that JP Alloys can refurbish back to original spec a 19-inch RS3 alloy wheel for £70 plus the dreaded VAT (£65 + VAT if the tyre has already been removed). If a Matt finish is required then this is plus £10 as the wheel has to be re-lacquered to provide that finish.
    I have seen their diamond-cut work and it's gob smackingly good.
    JP Alloys price includes:
    • the removal of the tyre
    • stripping off the original paint/lacquer
    • repaint to original colour
    • diamond cut
    • re-lacquer
    • re-fit the tyre with new valve and balance.
    JP Alloys are, as I write, discussing a collect and return/delivery service with UPS
    So have a talk with Pete (01543 503362) and discuss what you have.
    Or, the cheapest option, stay away from the bl##dy kerbs!
    Vito and robbiemac like this.
  35. Kohaku
    Kohaku Member
    196
    27
    stay away from the bl##dy kerbs! .....I Agree
    No bonus points for clever parking,and of course always take the obligatory 1 and a bit parking spaces in supermarkets.
    Or the Blue Badge scheme (Marvellous) although it does draw attention.
  36. 45bvtc
    4,384
    7,666
    BAD boy Kohaku...
    Still the fastest blue-badge car in Cornwall (UK) then, Ian? You're bad, really bad... but I (maybe) like you.
    Very best regards/wishes to you both...
    PS: can you send me a photo copy of the badge?
  37. Kohaku
    Kohaku Member
    196
    27
    The fastest in the country,if not the Woorrrld,as you know who would say.
    The Bad Boy is the car...Must admit tho walking permanently leaning to left doesn't do alot for the image
  38. Kohaku
    Kohaku Member
    196
    27
    Stand back please...
    OAP engaging Launch Control.
    Vito likes this.
  39. Vito
    Vito Active Member
    163
    86
    And that`s another option, thanx P_G :icon_thumright:
  40. Vito
    Vito Active Member
    163
    86
    OMG !!!! what am I reading here, I can just picture in my head 45btvc and Kohaku racing each other on those electric scooters (remapped ones of course):laugh::racer:
