Kerb Weights
Pubemammal Jul 19, 2013
  1. Pubemammal
    Pubemammal Active Member
    528
    117
    43
    I was looking at some specs of different models of A3 8L and thought that the diesel models would be a lot heavier. Specs on every site say that the diesel (pd130) weighs 1175kg kerb weight and the 1.8t weighs 1145kg kerb weight.
    So are the diesel models only around 30kg heavier? I thought they would be at least 100kg between the two!
  2. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    the diesel engine is completely cast iron, so the only weight addition really is the cylinder head over the alloy 20v head. Everything else mechanically is probably very similar
  3. Prawn
    11,676
    3,673
    truth be told, those weights arn't correct anyway, unless they're totally dry weights with nothing in at all, no fuel, no fluids, no spare tyre etc etc.
    realistic weight for a 1.8T FWD is around 1220-1240Kg
  4. JimS3
    JimS3 Active Member
    736
    72
    The PD engines have aluminium heads, at least every one I have rebuilt has, and all transverse ones should be the same.
    I very much doubt the pd130 A3 weighs 1175kg. I have a golf MK4 PD 130 as my daily drive and I put it on a weighbridge and got just over 1310kg.
    The non PD will be a fair bit lighter. The extra weight in the PD130 is partly in the larger head with the rockers, and unit injectors. The rest is in the 6 speed box, bigger clutch, flywheel, much heavier driveshafts, CV's, brake discs etc. Basically everything is beefed up to handle the torque!
  5. superkarl
    9,610
    2,481
    Weird, i have one sat next to my car in the garage, i swear its all iron.
    Anyway, who gives a **** why a diesel is heavier than a petrol. Whats the actual point in the post
  6. JimS3
    JimS3 Active Member
    736
    72
    Sure its a PD head? Stick a magnet on it!
  7. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    100kg is A LOT of weight.
    And as Prawn says, those figured are wrong anyway.
  8. Pubemammal
    528
    117
    43
    LOL.
    Ok thanks guys.
  9. Cobra88
    Cobra88 Active Member VCDS Map User Audi A4 Audi Avant Owner Group TDi
    553
    70
    All the TDi's have Ally Heads not just the PD ;)
  10. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Well my S3 is listed as 1,461kg in the boot if that's any help.
  11. 16Klappe
    5,795
    1,187
    No, no it's not.
    :p
  12. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    That's about the weight of a mate of mine & you KNOW when he's in the car!
    Pubemammal likes this.
  13. 16Klappe
    5,795
    1,187
    I feel the same about when I fitted Recaros.
