Keeping DRLs lit
mitch78 May 28, 2008
  1. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  2. Carpy25
    Carpy25 Member
    279
    Sorry for being dull but whats DRL's read both your posts about this and i'm dull ?
    Rob
  3. mitch78
    2,350
    :thumbsup:
  4. Carpy25
    Carpy25 Member
    279
    got it so when you switch you dipped lights on they go out . the dipped feed goes to the DRL relay and switches it off so the easiest way would be to replace the cut feed with another one triggered from the dipped feed
    simply put a live to the DRL with a second 12v supply that only works when the dipped lights are on , should be easy to do
    does this make sense
    Rob
  5. mitch78
    2,350
    :thumbsup:
  6. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    Now I'm feeling a bit thick cos if they were Daytime Running Lights wouldn't they be on all the time anyway? Isn't that the point of them?
  7. mitch78
    2,350
    :thumbsup:
  8. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    Should be something in VAGCOM for that. I'll take a look later.
  9. Kontraband
    Kontraband Active Member
    2,008
    Why do you want them on Mitch?? Asthetics?
    Only noticed myself a couple of days ago then went off when the headlights came on, as I set behind a chelsea tractor admiring my xenons. ;)
    Thought they may look better 'fully lit'?
  10. mitch78
    2,350
    :thumbsup:
