Karcher Foam Lance
jay07 Apr 5, 2008
  1. jay07
    jay07 New Member
    Hi
    Does anyone use a Karcher foam lance for snow foam application?
    If so how good is it?
  2. richjohnhughes
    richjohnhughes Member
    104
  3. N8
    17,163
    718
    Was looking at that post the other day! LOL
  4. Ian W
    Ian W Active Member
    1,058
    12
    I was looking at it today !
  5. richjohnhughes
    104
    i use the karcher foam bottle, but just on the end of a hose - and it gives the same results from what i have seen.
  6. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    The Karcher brand foam gun that can be bought for around £14 from places like Halfords is okay, giving plenty of foam, albeit thin and fairly runny. Much better if you can afford it is an Auto-Brite style lance, which will give a huge amount of ultra thick clinging foam, albeit for nearly £50. Here is an example image showing how good the foam from the latter is...
    In all cases, no matter what foam gun you use, the best foaming agent in my opinion is Meguiars Hyper Wash; gentle but effective, and a crazy 400:1 dilution ratio!
  7. 1animal1
    9,978
    so how long does that last in terms of washes
  8. buckas
    buckas Member
    749
    where could i buy the 'rubber dingy' floormat from?
    cheers
  9. 1animal1
    9,978
    id bet that has a generator attached
  10. axelfols
    axelfols Member
    127
    Theres quite a few foam lances for the Karcher. Whats the best one to go for as the prices are pretty varied?
  11. WX51TXR
    1,452
    14
    One bottle of Hyper Wash lasts us around a month, using it every other day... so for home use it will last a lot longer!
  12. WX51TXR
    1,452
    14
  13. WX51TXR
    1,452
    14
    Auto-Brite lances are typically very good, and worth the money - I agree that some of the others aren't up to the same standard. :yes;
  14. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,766
    208
  15. WX51TXR
    1,452
    14
    It'll be the shampoo - you need Hyper Wash in your life for sticky foam! :)
  16. jm-baker
    jm-baker Member
    230
    Is it best to use warm water with the lance? I might try and hook up a warm water tap outside if the benefits are worthy...
  17. WX51TXR
    1,452
    14
    Yes, absolutely - warm water vastly enhances the cleaning power of foam and of water itself, to the point where touchless washing is almost possible with a hot water pressure washer. Think of it like doing your dishes after a Sunday roast - with cold water no chance, but hot water, cuts the grease and fat no problem at all. :yes:
  18. c_ken
    c_ken New Member
    what is the right amount ( in ml.) of hyper wash in 1 L. bottle for
    sticky foam and not stripping wax/lsp
  19. jr001
    jr001 Member
    380
    Yeh, being able to hook up to a hot water connection is worth the effort. I've always used the cold water tap on the outside wall. Just recently though, my brain has come alive!! My drive is right outside the kitchen window so I bought a connector for the kitchen hot water tap and I've revolutionised my own wash routine, all for 8 quid!! Don't ask why I didn't think of that before please!!
    The pressure isn't as good as the CW pressure but it's well enough for the job.
    I use 200ml Autobrite SupaSnowFoam and I add one dollop of Maxi Suds and have been pretty happy with that combo. Now it's even better with the hot water!! Every stage of the wash is now with hot water and the difference in the car's appearance is very noticeable. Richard is correct in saying that it almost produces that touchless wash solution to a tee.
    Now, finish it all off with a hot water hand wash (if you have the time) and do all the rinsing with hot water and you will achieve the best wash you can get.:icon_thumright:
  20. WX51TXR
    1,452
    14
    About 100ml of Hyper Wash is about right, and you should then fill the rest of the bottle with warm water to the brim. Then screw the injector head back on, shake gently to mix the contents and then you are good to go. :icon_thumright:
  21. WX51TXR
    1,452
    14
    Woo-hoo! One you have moved over to hot water for the whole procedure, there is no going back lol! :cool:
  22. c_ken
    c_ken New Member
    Thanks a lot Rich, one more stupid question.Do you usually foam the car while it
    dry or pre rinse?
  23. WX51TXR
    1,452
    14
    I tend to pre-rinse with hot water these days, but in reality it makes little difference. Using cold water, I'd be more likely to foam first onto the dry car, then rinse this off at pressure after 5 minutes, then foam again prior to hand washing. As I said though, dry or wet makes relatively little difference. :)
