Can someone please tell me whether the oil return pipe is meant to be this close to the bottom mount as I've recently had it rebuilt n have a feeling they put it back together incorrectly. I can't see how the bracket on the car will fit.
I've turned the hot side round slightly so it's an 1/8" further away n now the actuator arm doesn't come out square, does this matter? Can't turn the comp housing as that's in the correct place due to the water pipe with small bracket.
