K04 Threaded insert replacement?
s3dave Aug 6, 2012
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    My K04 Hybrid has just blown its second gasket on the manni to turbo bit, while getting the studs out ok, one of the threaded inserts as come out with it, and fell down the back of the engine somewhere, tried for 4 hours searching for it with magnetic screwdrivers and around 50 pics on my phone of every inch of it ,,,and it has just vanished.......soooooooo. where can i get a replacement from? im used to nutserts in my line of work but it is double threaded, and thats where my dealings with this sort of thing are finished...
    It is like an helicoil but with a rim on it, or what about this?
    1 x WURTH M10 x 1.5 TIME-SERT INSERT 20mm length - 1 x Insert | eBay
    Does anybody know if that is the correct size? or have an old one of a knackered turbo?
    (And before anybody says did it drop in the turbo..no it def fell down the back of the engine at the back of the turbo)
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Dave I need 5 of them so let me know if you find a supplier:) but you're in luck as one of the housings I have has 1 in it, if I get a chance I'll rove it tomorrow and chuck it in the post.
    I personally don't think you'll find replacements, I'm planning of Tig welding studs in there as I'll don't think I'll get any.
  3. Prawn
    11,610
    3,597
    Jesus Dave, you have some luck don't you fella!
    Poor ******* :(
  4. s3dave
    10,110
    736
    Oh cheers Dan that would be great, i can send you down some m10 nutserts to weld in if you want? I just want to try get it in in situ so welding is not an option... do you know if that is the correct size?
    Haha Pawn it would be boring if drama never happened as im sure you will know....;)
  5. beachbuggy
    1,931
    202
    No problem, if you send say 3 down, if it's not a hassle I'll give them a go. I don't know what size they are unfortunately . I had considered just welding up the hole and getting them drilled and tapped but think just welding the stud in place may be the easier option , wouldn't mind trying the but inserts though.
  6. Westy
    Westy Well-Known Member
    17,443
    1,105
    Those inserts are a massive PITA. I had 1 come out on the stud when I did my rebuild and we had to leave it soaked in WD40 over night to separate them. I hate them.
  7. jay106
    jay106 Member
    58
    Hi did anyone find were to buy these inserts from bought a ko4-23 turbo set up and one is missing any info would be helpfull Thanks
  8. Westy
    17,443
    1,105
    I think Beachbuggy found a place that supplies them but I might be wrong.
    jay106 likes this.
  9. beachbuggy
    1,931
    202
    i found an old knackered k04 and took the inserts out of that... Only way it seems.
  10. jay106
    jay106 Member
    58
    its a nightmare in it i only need 1 are they stranded on all ko4s then?
  11. jay106
    jay106 Member
    58
  12. jay106
    jay106 Member
    58
    as above i found a link that someone used to makes theses kits on one of the forums years ago is anyone making these anymore?
  13. s3dave
    10,110
    736
    They are a nightmare to find, a guy was supposed to be making me some, but keeps making excuses so it looks like the end of that, somebody said backdraft motorsport might sell them?....
  14. jay106
    jay106 Member
    58
    i only need one to finish off my ko4 set up on my agu engine that all i found is that pic and the guy was seling them but that was years ago lol.could plz let me know if you get and luck,how come audi dont sell them
  15. Westy
    17,443
    1,105
    Audi dont sell them because it's not an audi part. KKK or someone supply the turbos. It's the same if you wanted 1 screw for the Bose amp, they'd probably tell you to buy a brand new amp from Bose.
    I've read about people using a Helicoil to do the job. Might be your answer. Other then that, I would call up the turbo refurb places like CR Turbos or Turbo Dynamic and ask them for some advice.
  16. jay106
    jay106 Member
    58
    just rung back draft motorsports no luck they suggested second had or look for the same type off helicoil :banghead:
  17. jay106
    jay106 Member
    58
  18. Westy
    17,443
    1,105
    Same sort of thing as Helicoil. This would be your solution if you cant find a genuine insert.
    What happened to the insert you're missing?
  19. beachbuggy
    1,931
    202
  20. badger5
    9,559
    2,028
  21. jay106
    jay106 Member
    58
    well i got 3 on my turbo now i could spare one as cars going off road Till i get it done how long do You think it will take thanks
  22. jay106
    jay106 Member
    58
    will a helicoil withstand the heat?
  23. Westy
    17,443
    1,105
    If you've got 3 why do you need another?
  24. jay106
    jay106 Member
    58
    2 i meant to put sorry guys lol
  25. jay106
    jay106 Member
    58
    when i was stripping all parts off donor car i must of lost i didnt even know it was any on the turbo till i took a closer look at it
  26. badger5
    9,559
    2,028
    m14x1.5 into M10x1.5 is the thread adaption
    jay106 likes this.
  27. jay106
    jay106 Member
    58
    ok thanks alot what should i be looking for now a helicoil with that size?
  28. jay106
    jay106 Member
    58
  29. badger5
    9,559
    2,028
    the screw insert is not a heli coil, its a thread adaptor.
  30. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    Westy likes this.
  31. jay106
    jay106 Member
    58
    Just pmd him just hope for the best
  32. jay106
    jay106 Member
    58
    ShowImage.jpg still looking but think iam getting closer
  33. hardhitter
    hardhitter Member
    138
    I may have found something:
    KOBSERT® threaded bushes for metals - Böllhoff
    They do an M10 internal thread with M14x1.5 outer thread. Just depends on the shoulder size as you would want the insert to bite into the housing.
    If these work, do I get a prize ? :cool:
  34. s3dave
    10,110
    736
    The problem is getting from a m14 outer to m10 inner... nothing standard off the shelf will do that, it is a specialized part, quite interested in what Sidey found though, looks promising...
    Standard ones are stainless by the way...
  35. s3dave
    10,110
    736
    These work like the timeserts it will cost you around £220 for the tool + inserts believe it or not....
  36. jay106
    jay106 Member
    58
    thats all i know is what bager5 told me earlier is m14x1.5 into M10x1.5 is the thread adaption if you can get them and get price loads of people need them
  37. Andrew@A.L.D
    3,879
    617
  38. jay106
    jay106 Member
    58
    right guys i think iam willing to send one of mine into badger5 so he can make some up anyone else be intresed if he makes some up?
  39. Lewis583
    956
    91
    The Wurth Timeserts are mega expensive for the tiny kit you get. £1 an insert too for when you use the 5 that come with the kit. Far better than heli-coil though in my opinion.
    I have a dud K03 down the shed, so will see if I can get the inserts out of that and get some detailed measurements/drawings made.
  40. s3dave
    10,110
    736
    no mate unfortunatley
