k04 manifold
Audakas May 17, 2012
  1. Audakas
    Audakas Member
    101
    Hi my xs power manifold just craked again 3rd time after re welding 2 times im sick of it. shall i stick whit original k04 manifold or go for expensive jbs wondering what advantages i would have?
  2. <tuffty/>
    21,134
    3,825
  3. badger5
    9,469
    1,988
    Version 1 or version 2
    cracked where exactly?
  4. Westy
    Westy Well-Known Member
    17,443
    1,103
    That's bad. Only seen Prawn's crack and he seriously abuses his car. What are you doing to your car :faint:
  5. badger5
    9,469
    1,988
    XS/Relentless mani's have been cracking for a long time Neil... its not unique to prawn...
    hoping V2 is going to be more robust.... but...... time will tell on that score
  6. Westy
    17,443
    1,103
    That may be the case Bill but there's a lot of these manis on cars now and the reports of them cracking haven't been that common. Especially not on here and especially not 3 times!
  7. Jimgrim77
    Jimgrim77 Member
    957
    20
    Not version 2's...yet. V1's plenty.
    Still not sure which version here has cracked though. Hoping v1.
  8. badger5
    9,469
    1,988
    V2's have not been running on cars very long yet............
    fingers crossed of course but......
  9. Prawn
    11,495
    3,409
    3 times on the same manifold is meaningless though westy, as a repaired weld is never going to be as good as te original, so it'll always go again
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If they were welded with rod that is, the V1s looked to have a lot of there joins fused in with no rod,,, to make them look pretty no doubt...
  11. Westy
    17,443
    1,103
    Also cheaper to make I assume Dave?
  12. badger5
    9,469
    1,988
    thing is Dave... so are the V2's in many joins. Fusion only welding is fine if back purged and fully penetrative which they are'nt. I used to make coriolis mass flow meters which were C22 or 316L tubular instruments, which we orbitally welded.... 100% penetration, perfect fusion only welds. Post weld vacuum annealed however to normalise the materials and welds.. On tensile tests when I qualified the weld process, the tubes would break everywhere except the weld joint.
    I have had 3 relentless manifolds sent here in last 2 weeks.... for welding before fitting. fusion welds on the runners, and some filler on the collector area seems the norm. they have gone "tink" "tink" when welding... from localised expansion. Hope they work ok in service. Fitted 2 to 2 cars in the last 2 weeks also.. PIA that they are to fit, lol
    I think we're all hoping they hold out a reasonable time..... but I am realistic that their construction methods dont help that cause.. but am happily proved wrong, as they flow very well.
  13. Jimgrim77
    Jimgrim77 Member
    957
    20
    I suspect that they will crack if subjected to insane temperatures with regularity.
    Many users seem to be cranking up their maps and perhaps going too aggressive.
    Anyone having their car tuned without someone really knowing what they are doing are at risk with this part, it's as simple as that.
    We've been closely monitoring the temperature on mine because it was running was too hot, but I've been checking it almost weekly for 4 months. I doubt whether many others will be able to be so thorough.
  14. Audakas
    Audakas Member
    101
    i abuse my car aswell but only sometimes. but i think that v1 not to sure. but when i fitted after three weeks. its cracked re welded again another couple weeks cracked an fact i have a turbo timer set all the time to let the turbo cool down whit manifold im really disappointed probably gonna use the standard manifold.
  15. Prawn
    11,495
    3,409
    well that's me ****ed then isn't it!
    Mine cracked on a trackday on actuator pressure, you can't turn the boost down any further :p
