K04 hybrid
G"MAN Nov 2, 2009
  1. G"MAN
    G"MAN GONE LOW BUT GOING LOWER
    82
    hey peps looking at uprating my turbo from the k03 to the ko4 what else will i need to change for it to work propley i know it will need mapping.. will the down pipe for the k03 fit the k04 and will all the bost pipes and intercooler pipes fit too..
    thanks G
  2. S3-Dan
    S3-Dan Quattro
    179
    are you going K04 or K04 hybrid ?
  3. G"MAN
    82
    will be going hybrid hopefully..
  4. Broken Byzan
    13,237
    465
    If the Hybid into your casing then it's all a direct bolt in. If you buy a K04 and get that hybridised, then the manifold/DP/Tip etc are more than likely different. Certainly are on an 8L chassis car
  5. G"MAN
    82
    so im basicaly looking at changing the downpipe and charge pipe thats not too bad then will have alook into it more..
  6. navnayyar
    navnayyar Member
    756
    will also have to re-jig pipework from intercooler, k03 and k04 pipes are slightly different
