K04 hybrid mapping?
S3 GEORGE Apr 8, 2009
  1. S3 GEORGE
    S3 GEORGE GEORGE
    109
    Hello
    I have a s3 2002 bam
    Turbo Dynamics can hybrid a k04 to so they say to 240-260bhp
    they recommended you to map it is this possible and will I really see that kind of power?
    MD421 Modified compressor housing inlet, C.N.C re-profiled compressor cover for high flow
    compressor, 2283 Spec “Billet Aluminium” Lightweight Compressor Wheel. modified
    seal plate, 360 degree thrust bearing, K04 Large trim left hand thread turbine wheel with
    lightening of turbine wheel for faster ‘spool up’, C.N.C. modified turbine housing for
    higher flow, up-rated twin turbine seals, 0.8 Bar up-rated actuator. Other ‘blueprinting’
    modifications. APPROX 340-360 BHP Max recommended boost pressure 24-26 PSI.
    I was thinking of geting a tublure manifold, 3 ince down pipe and a 110 cell high flow sports cat how does that sound?
    Will i need injectors or any other bits?
    Regards
    George
  2. S3 GEORGE
    S3 GEORGE GEORGE
    109
    or if any 1 else has some idea on power or seen the hybrids in action
    let me know
  3. hutchybee
    hutchybee Faux Musician
    85
  4. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,246
    2,069
  5. ben@amdessex
    ben@amdessex Member
    290
    20
    Hello George,
    We can do a custom map to suit your car and the mods.
    What other mods have you got on the car?
    Ben
  6. S3 GEORGE
    S3 GEORGE GEORGE
    109
    im fitting a fmic tubular mani 3 inch dp 110cel cat
    do you map alot of hybrids?
  7. ben@amdessex
    ben@amdessex Member
    290
    20
    We have two cars in at the momment with hybrids on and thats just this week. We have done quite alot of maps for hybrid turbos. So we are not strangers to them.
    Ben
  8. S3 GEORGE
    S3 GEORGE GEORGE
    109
    What hybrids are they running? do you see much difference with all the hybrids out there?
