K04 Conversion On Audi A3 AGU HELP PLEASE !!!
Chester999 Jul 2, 2012
  1. aragorn
    18,043
    729
    similar here, -22 or so.
  2. Chester999
    Chester999 Speed Freak !!!
    325
    12
    cheers people looks like i have a leak some where then mine only reads -10 need to get it sorted before i go for the map.
  3. aragorn
    18,043
    729
    yeh that high is defo a leak!
  4. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Mine read -10. Sorted out a couple of **** joiners and it went to -22, so it's definitely a leak.
  5. Chester999
    325
    12
    Just a quick question does anyone know if my boost gauge will read different if my car has been chipped as it had a 195bhp oettinger chip in it when i bought it with the k03 on there and am now im running a k04, badger5 tip,wellcooler, have a had quick look over car and cant find no leaks will have a proper look this weekend just want to know if i will get a different reading on the boost gauge or should it still be around -22psi ???
  6. superkarl
    superkarl MAN OF STEEL
    9,406
    2,379
    you have a totally different turbo, and other hardware, it will be different. you should be on actuator really until you are mapped for the hardware you have now.
  7. Chester999
    325
    12
    ok cheers karl thought the reading would be off a bit my boost gauge reads -9 / -10 psi on idle so that could be right then with no vac leaks and i try not to drive the car that much but when i do i only hit about 3000rpm in each gear not even that so should that not be running actuator pressure if im not even hitting the boost should be going for the map next month hopefully.
  8. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    you should still be runing the standard maf and have the n75 unplugged, until its mapped.
    Your vac reading at idel should still be the same weather you have changed turbo and other stuff. (I am only saying this from first hand experience from when I rebuilt my engine then changed turbo and Fmic)
    I would take it some where to get it smoke tested to double check.that there is no leaks, leak could be anywhere. Under the manifold, pcv pipes, carbon canister pipes I think they are vacuum.
    Just check every pipe lol it doesn't take up a massive amount of time.
  9. aragorn
    18,043
    729
    you should still be getting -20ish at idle, turbo etc doesnt affect that.
  10. superkarl
    9,406
    2,379
    OP, you shouldnt get -20 PSI, aragorn is refering to Inhg.
    your -9/10 psi is infact about -19inhg, so you're OK :thumbsup:
    Chester999 likes this.
  11. Chester999
    325
    12
    Still looking for some new bosch 440cc green top injectors if anyone has any or know where i can get any ???
  12. Chester999
    325
    12
