k04-023 turbo only!!??
KEF A3 20V T Oct 31, 2006
  1. KEF A3 20V T
    KEF A3 20V T Turbo's Rule
    199
    hi was wondering, i have a k04-023 turbo sat in my bed room gathering dust was wondering if i would be able to just fit that without injectors n maf?? would it work or not???:shrug:
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    Not a chance fuelling and airflow would be all over the place,at your own peril.
  3. madvw
    madvw Active Member
    2,489
    would it? surely the boost would be monitored in the same was as before, just the wastegate would open earlier as the boost limit was reached earlier?
    i'm no expert any level on turbo's, but i'd expect it would work fine - you'd just be waste(gate)ing all that extra boost you could be using.
    A custom remap is the bare minimum for installation and seeing any benefit.
  4. Tallpaul
    Tallpaul Member
    835
    Is this a theoretical or practical question?
    I guess theoreticaly just changing the turbo would be OK at low-mid revs. I'm not sure the N75 would necasserily be OK on it's own under full load. You don't even want to risk running lean IMO.
    Practically you can't just bolt it on. Your mani, downpipe, oil/coolant lines and turbo intake pipe are all the wrong size/in the wrong place.
