K04-015 for QTS
alex-qts Nov 30, 2009
  1. alex-qts
    alex-qts Member
    59
    hi all,
    havnt been around much as i have relocated to southampton for uni!
    i have a 2000 a4 qts (180hp) with what i understand to be a k03s turbo.
    the turbo is failing and leaking oil according to garrage, no power..., much slower car all in all. so i need a new turbo.
    what i wanted to ask is: if i was to go for a K04-015 and get it fitted, would it:
    A) work without ECU upgrade, even if it ran at 180-90hp?? or power band /torque diffrences?? or would it NEED an upgrade to work?
    B) Be a direct fit?
    i dont really care about increasing the power on a huge scale, but some small gains past 180 would be nice! at the moment its just not a good driving experience!
    any adivce would be really appreciated as there is so much info out there and im getting so confuised with reading conflicting information.
    also would anyone know a good supplier to get an original borg warner k04-015 on a tight budget? i really dont have the money to go down the "G" route either!
    thanks for any help guys!
  2. aragorn
    18,022
    718
    it would bolt streight on but you wont see any more power unless you got it remapped.
    They're also about 7-800quid new
    The other option for an almost-as-good upgrade is a K03-073 from a B6 A4 with the 190hp engine, which you might be able to pick up second hand.
  3. docurley
    4,070
    85
    Just don't buy them ebay fakes
  4. alex-qts
    alex-qts Member
    59
    thanks guys im going to look into the 073 and see what i can find. as im not going to remap it may be a better option.
    although the power is not increasing would the k04 add better torque/spool up than the k03s. without remap?
    cant wait to get the turbo in, then its only the leaky radiator to fix and she's back up and running.
    also she is not handling good at high speeds, i think some of the joints are broken as its got the banging while braking noise. its got worse - now i can hear it when turning corners too!!
    oh deer, what will be next....! dont think i could sell though, love her too much.!!
    :blackrs4:
  5. aragorn
    18,022
    718
    K04 will be more laggy i would imagine, as it has a larger turbine wheel and therefore more energy is required to spin it up.
    If your keeping the car standard then fit any old K03. It seems the TQS models didnt get anything special, just a plain old K03-005 like most other 1.8T's. Only late 150hp DBW cars got the so called "k03s", which is acually a k03-029, and is fitted to ALL B6's bar the 190.
    Any B6 turbo will be an improvement over stock, as all B6's had the K03-029 at least.
  6. alex-qts
    alex-qts Member
    59
    just found a k03-073 recon for £440 so might just go with that
    its got 3 month waranty and all new parts, and pressure tested
    cant remember if that price was including vat or not lol
  7. Kingfisher
    Kingfisher Active Member
    262
    45
