k03s turbine shaft bent
norfolkaudi Apr 28, 2012
  1. norfolkaudi
    norfolkaudi Member
    hi all
    i have just got my k03s turbo (ebay) and on taking it apart i find the shaft has a slight bend in it
    so what do i need to do???
    replace the shaft with k04 shaft, i now that the k04 shaft is bigger but does that meen that the
    bearing is thiner, i understand that the k04 and k03 use the housings.
    would it be just the case to get k04 shaft and k04 bearing and will it be a straght swop in
    the k03s housing.
    the engine is agu.
    tim
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    K03 and k04 have the same shaft just different sized wheels. K04 won't fit directly in k03s housings. It will all need to be balanced.
  3. norfolkaudi
    norfolkaudi Member
    hi ok i can unerstand that so can there be a small amount of bend in the shaft cold side???
    and there must be some kinda upgrade to the 4mm shaft cold side???
    and how would i get it balenced
  4. sportquattro
    sportquattro Active Member
    834
    51
    I wouldnt have thought any knd of bend would be good for the turbo longevity, given toe RPM a turbo spins at, any bend will cause inbalance issues. Was the turbo sold as fit for use? If so I'd send it back and get a refund if it was me
  5. <tuffty/>
    20,847
    3,687
    Don't mix up float/clearance with bent... a bent shaft is a bent shaft and has no place in a turbo...
    Get the turbo refurbed by a company that knows what they are doing mate...
  6. Customboy
    Customboy Member
    831
    42
    Bin it and go for the ko4 like me !!!
  7. norfolkaudi
    norfolkaudi Member
    thanks for the info, but i got the turbo at silly price and on looking around i could get the shaft and balenced and seal kit
    for less than most peeps are paying for secondhand k03s.
    so if there is any one out there that knows the part numbers for shaft and where to get a good price on balencing to
    please send me a pm and we can do something.
    norfolkaudi
  8. 1982robw
    1982robw New Member
    what did you get done to your K03S in the end?
