K03 question
jay1601 Apr 12, 2011
  1. jay1601
    jay1601 Well-Known Member
    1,347
    73
    hi,
    just need a simle answer really.
    had my car mapped a few weeks ago, AGU block.
    the problem i got is the car will boost to around 14/15PSI. but within 1000-1500RPM boost will drop to 5/6 PSI
    i know the K03 isn't the biggest of turbo's but i would of though it could hold its boost a bit better then it is.
    i can't find any boost leaks, no fault codes.
    is this normal for a K03 or could it be the first signs of turno failure ?
    thanks for any help Jay
  2. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    sounds like ur waste gate isnt holding the boost mate. Mine does this but not as drastic as urs. mine boosts to 20psi then drops to 17psi on full boost
    either that or a boost leak. Did u check the FMIC pipes?
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Because of the limitations of th kkk series turbo's they tend to be mapped so the boost increases to a max psi then will taper off. I would have thought maybe you've got a bad actuator or possibly n75 valve or even DV. There is also a possibility you have a not so good map, but I guess you went for a main stream one so unlikely.
  4. jay1601
    1,347
    73
    Can't find any boost leaks on any pipes
    DV is only a couple of months old so hopefully its not broken
    Remap is a custom code done by storm developments
    Any way to test the wastegate/actuator?
