K&N Air Filter
jdp1962 Aug 29, 2005
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,119
    2,577
    Has anyone used one of these? If so, is it a worthwhile mod for a 2.8 30V?
    K&N Clicky
  2. Danielson
    Danielson Member
    704
    you want to ask that over on audizine my friend, you may actually get a respone on there, its pretty dead in here lately. =( or is it jus me!!
  3. Kevint
    Kevint Active Member
    1,182
    I'm not an expert but I've read many posts where people think an after market filter can reduce the life/performance of the MAF.
    Kev.
  4. Danielson
    Danielson Member
    704
    only if they are over oiled.
  5. fallmonk
    fallmonk Turbo Sport
    1,868
    Hi mate , i fitted a K&n pannel filter a while back , works fine , no problems with the MAF , wot im told is you need to watch when you re-oil it , lets face it K&n are a huge company whey wouldnt be aloud to build some thing that could damage your engine ! gives you a slightly "raspy" noise , am told it will give a few(2or3bhp) just cause the engine breaths easier and if turbo model it helps power build quicker!
  6. Kevint
    1,182
    Mick,
    You may well be right, but it's not a case of K&N building a filter that will damage your car. It's a case of Audi using a MAF which is prone to failure under normal conditions, let alone non standard ones.
    Kev.
  7. dann959
    dann959 Member
    91
    my maf went at 60k i had a k&n fitted into the box at 53k when i did my power chip. whether or not the k&n screwed up the maf in 7k is still in the air, but with all the time and confusion it took to get the problem sorted out it was enough to make me go back to the standard mann oem filters
