just wondering
turboaudi Jul 16, 2007
  1. turboaudi
    turboaudi Member
    58
    :think: i am going to take the throttle housing off the car to spray some carb cleaner in to it and give it a good clean out. would i have to get it recalibrated afterwards or could i just bang it straight back on after i clean it. thanks in advance chaps
  2. billybravo
    billybravo Active Member
    1,045
    after your done put your key in and turn the power on but dont start the engine or the throttle then the ecu should calilbrate it for you.
    it takes about 30secs
  3. johnyj
    johnyj Member
    264
    think u need to take the bat lead off first
  4. billybravo
    1,045
    no you dont
  5. a4quat
    a4quat Member
    374
    i think there is also a gasket to buy first aswell, thats what i got told any way!
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    jsut do it with the engine running, cleans a few other things out too!!
  7. shineydave
    shineydave Member
    920
    if you do it using the key method it resets the valve to the learned positions which don't take into account any wear / movement in the body or flap. if you take the battery off all the learned values are erased and then it'll do a full callibration. under normal circumstances the key method will be fine but if you think something has got disturbed then the battery method is going to give better results
  8. johnyj
    johnyj Member
    264
    roger bravo
  9. docurley
    4,070
    85
    Or if you have vagcom you can get it to calibrate through that.
  10. 98 A4
    98 A4 New Member
    17
    when you put it back on, the car will do it automatically.
  11. turboaudi
    turboaudi Member
    58
    this is why most audi owners think this site is the dogs ********, you always get helped out
